AzViper
Over in another thread there is talk of counting grams with a another first time builder. So all this what weighs this and what weighs that got me thinking I had better check my total weight from my spread sheet that I had started before my build as some items had changed for the good yet I had added a few items. I went out and bought me a Dymo digital postal scale today to find out my true weight. When I added up everything excluding the Gimbal and GoPro from my spread sheet my quad weighs 3411 grams.
Now I did not have my extended 10mm rails, Y connector for the batteries, 20 inches of #14 silicone wire, foam under the batteries, braided loom, heat-shrink tubing, receiver antenna mount, and Velcro Straps listed in my spread sheet. When I placed the quad on the scale with everything mention excluding the DJI H3-3D Gimbal and GoPro 3+ the quad weighed in at 3458 grams. This is 47 grams over from the calculated weight due to the items in bold. I suspect these items in bold weigh more than 47 grams so some of the other items would appear to weigh less than the stated weight. With the DJI H3-3D and the GoPro 3+ the quad will tip the scale at 3720 grams plus maybe another 50 grams. My quad will be under by 670 grams under the 50% thrust of 4440 grams reported by KDE Direct.
Honestly I am shocked by how close my spread sheet was. I had figured 3685 but the items in bold were not added and with a flying weight of 3720 I am off by 35 grams. Now that 670 grams will be eaten up with some of the other gear for FPV and Telemetry. With 15x5 props I have room for adjustment as I can go bigger and gain more thrust if needed.
