Thanks Craig. Where did you get the latest version of the firmware, I've only been able to find the 1.3 version. Also, do I need to go into the motor config screen. I haven't ventured that far yet, do I plug the the USB cable into the motor port on the control board? Are you using sbus on this setup or conventional settings? Are you using a knob to get manual control of the tilt for straight down filming, if so, what are your connections from the gimbal board to the FC? Are you using a NAZA or other FC? Sorry for all the questions but just trying to get it all worked out.
I was able to take a 4 minute flight this morning to do a little testing, felt good to see some nice stock setting results even in the wind. Need to work out my yaw settings for my quad in the wind. Much appreciated on the vid's and screenshots!
John
http://tarot-rc-heli.com/Tarot-RC-Software You can get the latest here.
Yes go in to the motor config, the only thing I changed was on the roll motor, 80 to 85 should work well. Yes plug it into the motor port on the controller.
I am using sbus with a R2008SB Rx, I have the tilt connected to channel 5 on the RX and use the VR knob to adjust it. Of course with a regular RC radio you can configure it alot of different ways by assigning switches and such.
Hope this helps some..
Craig
