I've had a few people get the suppo motors after suggesting them and wanted to show you guys how i do the shafts so these adapters are rock solid. It takes a dremel. You take a graupner air screw coupler and lay it up to the shaft and make a mark where the set screw goes, it is basically in the middle, but you want to remove as little as possible so the set screw hits the edge keeping it all in place. after cutting int he flat spots, i trim whatever it takes to get the coupler down onto the bell of the motor so theres no shaft showing. it's like 1/8" too long then i just sand the edge so they slide right into the coupler like they were before i started. other than this you have to solder on the bullets to the motor. I'll come back by later today to post how you do the arms so these fit to them.
the reason to do all this is if your running a dji motor with a graupner prop and want a direct replacement that is tripple the power, lifts 2800g and will do it with the props you have now, this is one way to get-r-done. the set of 4 delivred is right at $100
