KoolKiwiKat is proposing some interesting components and this is a fundamental decision that every heavy-lifter must make: "lightweight sports car" with potential fragility or "over-powered tank" withbullet proof performance. Lotus vs Mercedes, if you like. With any electrical/electronic system, the closer you run to its rated capacity the higher your risk of failure will be. It's the same with mechanical systems - lighter equals more fragile. The gap between these two approaches can be closed (to some extent) with "money". So its one of those "pick any two" choices: lightweight, reliable, cheap.
Personally, to fly a RED, I'd go with the OP's approach - over-specify everything. Efficiency/flight times are much less important than reliability - long flight times are not needed, absolute reliability is.
This really is the seminal issue here for those of us building for professional use. I'm a cinematographer, and this is a platform for aerials, and as such needs to be reliable and safe. I am in total agreement with all the calls for redundancy, but I also completely agree with jess111 that by over-specifying the power train I end up with a system that runs cooler for lower current draws. I'm talking about lifting a camera package that will come in around 15-17lbs. Body, battery, lens, Focus motor, HD Transmitter (or downconverter box and SD transmitter). On average we're talking about more than 20K worth of gear just hanging from the gimbal.
As far as the motors go, the only commercial builder I've been in contact with is Al at Hoverfly, and those are the motors he puts in his heavy lifters. They may not be the end-all solution, but the footage I've seen online that I really admire has been shot from platforms with this configuration of motors, and an ESC based power train, and that is why I am trying to vet them. I'm not interested in being able to whip around with this multirotor, my experience with technocranes and cable cam work is that graceful fluid movements produce the best results, for both platform and the operator. And yes, longer flight times are a non-issue. I'd be perfectly happy with 5-6 minutes per pair of 5S batts.
Vortex :
And as far as 5s vs. 6s on the Axis, I can always change the batteries later if I'm not satisfied. Al at Hoverfly recommended the 5S 11,000, and since this is my first bird and his track record includes 2 years of building experience I dont intend to take that advice lightly. I've heard the same thing you have about the AXi's wanting 6S to meet their potential, but I will take someone's real-world experience over a datasheet.
koolkiwikat:
Thanks so much for all your helpful comments, You've made so many good points that I'm not sure where to start. eCalc is a little mystifying to me when I plug in the numbers I have, so I'm not sure how to proceed in terms of determining how much throttle I need to keep my bird in the air after a motor failure. Could you go into a little more detail if you have a moment?
you given me a lot to think about. The only portion of your first post I would take issue with the suggestion to use DJI. A buddy of mine just had an AD-8 built with Axi 2826 motors chinese ESCs flashed to work with the Wookong-M, and when he took it out for its first flight and put it in Attihold it flipped over and crashed. Just because they are large companies and popular doesnt mean their products are reliable. Hoverfly doesnt have a crash record that I can find, and their customer service is excellent, and that is why I chose them. That, and they are made here in the US.
This thread has already proved to be an amazing source of info, thank you all for your replies!!
