Old Man
I think that it is quite common with power-line inspection by helicopter below 400 feet. I don't know if the power companies care to notify landowners about such inspections.
Power companies maintain a utility "right of way" of "X" dimensions in width along the length of a power line installation and specify right of inspection by any method at any time. Access for them is a non issue, it's up to the adjoining land owners to adapt as necessary.
This thread has brought up a point that I think was contentious in an earlier post of mire relative to sUAS operators becoming cognizant of full scale flight regs. There's a lot that we must absolutely understand in order to fit within a system that has been in operation a long time before we started tooling around with RC models and multirotors. Most that do what we do have no concept of approach and departure corridors, approach and departure angles, pattern altitudes at general aviation airports, and the distance from runway center line that most aircraft fly at. Turbine aircraft use longer and wider approaches than piston twins, with twins still being further from center line than the vast majority of piston singles. Those are just starters and actually help with the see and avoid side of things. If you know where things are usually at you know where to start looking. OTH, the dumb student or low time private pilot circling his house at 500' AGL will always be a wild card...
