I thought I'd start this conversation with you guys because it's a very common term in full scale aviation and as the FAA (and other world aviation regulatory authorities) continue to integrate UAS and sUAS operations into their nations' airspace systems, you will increasingly hear the term "See and Avoid" mentioned.
"See and Avoid" refers to a pilot's responsibility/ability to maintain a visual scan of the area around his/her aircraft in order to see and avoid other aircraft. If every pilot is doing his/her job to "see and avoid" other aircraft then, in a perfect world, there wouldn't be any midair collisions between aircraft flying under "Visual Flight Rules". Visual Flight Rules, or VFR, refers to day or night flight operations where cloud conditions and inflight visibilities are good enough where pilots are responsible for their own navigation and collision avoidance. Even when pilots are on more formal "Instrument Flight Plans" where air traffic control largely manages their route and traffic avoidance, when clear of clouds pilots are still responsible for maintaining a constant watch for other aircraft with "See and Avoid" regarded as the last defense against midair accidents.
"See and Avoid" also makes an assumption about the other aircraft that you'll be looking for, it assumes that they are out there and available to be seen. As @SleepyC; mentioned in another thread, Ultralight aircraft in the US have some pretty liberal operating rules in that the pilots are barely trained and aren't officially licensed as Ultralight Pilots. Yet they don't have any of the restrictions that we are seeing being discussed for sUAS (should I just capitulate and start calling them drones? It would probably get us more traffic via Google!).
There are a variety of reasons why Ultralights aren't in a fight for their life as sUAS are but I'll mention three;
Another topic related to this is call TCAS, which you will also begin to hear a lot more about as regulations get closer. TCAS stands for Traffic Collision Avoidance System and it was mentioned in the House hearing on Dec. 10 regarding sUAS integration in the US. TCAS systems enable pilots to see other aircraft (provided they have a compatible transponder blipping away their position information) as a blip on a small cockpit display. More advanced versions also display altitude information and can provide collision avoidance directions when a collision is imminent ("Descend!"...."Turn right!"... followed (hopefully!) by "Clear of Conflict").
TCAS systems used to be big and heavy and their antennae large. In the last fifteen years or so we've seen units that can provide basic information and take up no more room than a pack of cigarettes on the panel brow. Technology is rapidly advancing and we may soon see a TCAS unit that can reside on our sUAS vehicles without killing endurance or useful load (an aircraft term referring to weight (fuel, pax, baggage, etc.) that can be carried in addition to the weight of the aircraft itself). This would be a huge step towards helping regulators to chill out as it would help resolve the inherent inability of sUAS pilots that operate beyond Line-Of-Sight to see and avoid aircraft operating in their area.
More advanced TCAS systems for sUAS that can integrate with air traffic control and that can communicate with their users back on the ground via telemetry will likely remove a major bottleneck in the process of integration. Until then, we need to understand and respect the concept of "See and Avoid" as it relates to full-scale aircraft operations and how it works against us as we fight for the right to operate sUAS within line-of-sight and beyond.
Hope that helps.
Bart
- they aren't being delivered to virgin users by the thousands
- they are large enough (and often colorful enough) for other full-scale pilots to "see and avoid" them
- most importantly, pilots of ultralight aircraft can move their heads around to scan their surrounding area in order to avoid other aircraft.
Hope that helps.
Bart
