I flew again today same issues after I unplugged and reconnected everything. I hooked up my laptop and looked at the setup I couldn't find anything obvious in the config. I check the sensor travels and they looked fine. Then I checked the Radio signals to see how that looked. Full stroke on all the channels was fine. I did notice the yaw was flat in the middle...Doh...After checking the radio the expo was at 100% not zero... I went the wrong way with the setting.
I was playing with my video camera and recorded about 15 minutes of video. The wind was blowing a bit (gusty) so it was hard to get a nice smooth flight path. Out of 15 minutes of video I got about 30 seconds of decent quality video..lol
It's kind of fun doing close passes to the camera I'll have to try again
Can you see I put white tape on the front arms and White pads on the landing gear runners! That helps a whole lot with orientation!You're certainly getting better at flying - no more crashes indoors
Ok, I'm stuck.. I can't seem to setup fail safe to work properly..at all. I think I'm just missing how it works. I have a Witespy multiwii 2.0, running multiwii2.3 firmware. I have a Turnigy 9XR transmitter with a Frsky tx module and Frsky V8FR-II receiver. I have modified the multiwii 2.3 sketch so that Failsafe is enabled. It seems like I need to do something with the radio because the signals to the flight control board do not change at all if the transmitter is turned off. This means the flight control board thinks everything is fine.
I also can't change the fail safe throttle level in the gui.
So how should this thing work? what should the receiver do when it loses signal?
Edit: The whole failsafe functionality is done in the radio alone. It confused me having the failsafe settings in the control board firmware.
