Benjamin Kenobi
Easy? You call that easy?
Hmm, maybe my explanation is wrong then. I'll sit down with it later and post some vids. On a train now. Cheers!
Well i have tried repeatedly to get this to work but to no avail. I have tried leaving the bind plug in, holding the bind switch for almost forever, releasing the bind switch quickly, no matter what I try the naza just will not drop into failsafe when Tx lost.
Interestingly, if I go full throttle then switch off the controller when connected to the assistant, the throttle drops to 50% so it looks like it has remembered that, just not the position of the failsafe switch. The only thing I can think of is that in order to get the two way switch to go beween GPS and failsafe, I had to reverse the gear switch it in the Tx setup, is this possibly where my problem is arising?
Hi Because of your post I realized I didn't have mine set up either so I thank you for posting your problem. I did finally get mine set up but it took about 7 tries to get it to take the setting. I almost felt like it was some sort of timing issue with holding the button down. Anyways this is the set of instructions I used that finally worked. http://www.xflysystems.com/blogs/ne...ur-spektrum-dx7s-ar8000-failsafe-for-dji-naza
I'm glad my post helped you before you found out the hard way That said I am really pleased with how durable these things are, even when you land it on top of the compass (sometimes depth perception is an issue for me, either that or those hedges are just jumping out in front of me) :0
Those instructions are for a DX7s and a different Rx so I think not relevant to my setup.
I am thinking its either a problem with the model of Rx I have, or its due to the gear switch being reversed. Later I will try to get something working without the switch reversed (which from my past attempts means I'll only be able to asssign manual and failsafe modes to the switch but it will prove the reversed switch theory I guess.
From what I understand at least on my system, once the value is stored in the receiver you can change the switch back to whatever way it was before and not affect what is stored in the receiver. I think? By the way, it did say in those instructions I followed that the Rx needs to be capable of storing a failsafe which indicated to me that some aren't. Maybe the one you have doesn't have that feature? (grasping at straws here I guess... LOL!)
The AR6200 features SmartSafe failsafe. SmartSafe is ideal for most types of aircraft. With SmartSafe,
when signal is lost the throttle channel only is driven to its preset failsafe position (normally low
throttle) while all other channels hold last command.
It's not the reverse of the switch causing the problem as I just checked it.
Then I read this in a manual.....
Looks like this is the problem, doesn't sound that "smart" to me
I think you are right on the money there unfortunately! Doesn't sound so smart to me either! LOL! Maybe bump up to an AR8000?
Will that work with DSM2, my DX6i is only DSM2.
Yep! According to this it does! http://www.spektrumrc.com/Products/Default.aspx?ProdID=SPMAR8000
thurcombe, sorry for confusing you. I'll try to explain myself a bit more.
There are multiple ways to get the Naza into Failsafe mode.
1. The easiest way is using the Naza Software Assistant, you can configure the U channel to be GPS, ATT, FS, and giveup usage of MANual mode. I personally do not like this because I want Manual mode available if I need it.
2. Setup the Naza for the U channel to be GPS, ATT, MAN, but then have the transmitter send a value (based on a switch) for the U channel to be in between those three mode into the region called Failsafe. This is something external to the Naza, and requires special programming in the transmitter. Sadly, I do not know the DX6i transmitter, so I can't help there, but I would search YouTube; that's where I found out how to do that for my Futaba. Basically you are going to do a "mix" of two switches. One three-way switch that commands max, middle, min values which associates the three positions to the three flight modes. Then you "mix" in another switch which adjusts that same output of the 3-way switch to force a value in the in-between area. This way you can trigger the Naza into Failsafe with this other two position switch.
The above two methods are the pilot triggered ways of getting the Naza into Failsafe, and it is advisable that you setup one of those two. However, there is the true Failsafe intent which is the case when communication between you and the Naza is somehow broken, typically because the receiver is no longer receiving the signal from the transmitter. That is the transmitter/receiver failsafe programming that everyone should also setup. If this is setup correctly, the Naza failsafe will kickin if power is lost to the transmitter, or the signal is lost because you flew out of range. Again, I don't know the DX6i, so I can't give you specifics. But the jist is that you program each of the outputs to a specified response if communication is lost. So on my Futaba I have the throttle output set to 25% if the signal is lost, and the U channel set to a value that puts the Flight Mode into the Failsafe region.
So all of the above settings/programming should be verified on the ground with the Naza Software Assistant running to confirm the Naza flight mode is truly "Failsafe". Then, once you have confirmed that, try invoking Failsafe with one of the switched methods. Once you have confirmed stuff and you feel confident, then maybe you can try the loss of power method, but just be careful. I have tested it that way, and as soon as I confirmed it was returning back home, I turned it back on just to give me that piece of mind.
As to another question you had earlier... "Intelligent" shutdown is what I prefer, so you're fine there. I was just wondering why your MR just fell to the ground, and I'm guessing the Naza is getting a zero throttle input when you power off your transmitter. You can double check that with your Software Assistant.
Hi Bensid. I will try to keep this brief just so that we don't get too far off topic.Propilot you say you have a Futaba? I have a Futaba 12FG and have not yet set it up for failsafe tell me please what settings you used and what channels are you using on your controller and your receiver. Thanks
Hey there! Sorry for delay.
You've gone off down the blaming equipment stage again. Stop it. The vast majority of Spektrum rx work exactly the same way. You can follow any instructions. You have the throttle channel correctly set (throttle goes to 50% when switching off) but you still haven't got your switch set to failsafe before binding. That is all you're doing wrong.
It doesn't matter if the switch is reversed. As long as the blue failsafe bar is on in the assistant when the two way switch (hopefully the switch on the front of the DX6i marked Gyro) is in position and in that same position before you press the bind button then it will bind.
Binding is binding.
Ps - I used the DX6i and that same receiver for 3 years. Believe me you are just binding incorrectly. Read the manual please
Ben can you please confirm if it was definitely the 6200 Rx you used as the more I trawl the internet the more I read that the 6200 does not support preset failsafe, only smartsafe.
Howdy, it was indeed that rx. I used the gyro switch on the front though. Maybe that's your problem??? Hmm. By the by, sorry for sounding so preachy. It just sounded like you were trying the same thing over and over without changing anything which was frustrating.
Smartsafe is failsafe!!! Don't let the branding get you. Smartsafe is Spektrum failsafe.
Now go and change the switch you use to the gyro (including swapping the rx wires around) and see if that makes a difference. Your switch is not working properly or is not suitable for binding. I use a helicopter model on mine as I want throttle hold so using the gyro switch you just adjust the gyro gains to enter the various modes.
Good luck mate! You can do it!
