Rabbit fc
crusher
I see that there are several different threads on several different fc boards but i dont see anything on the rabbit.. Could someone tell me where to look to get some help or can someone here help me with my issue?? Rabbit fc will not arm
Pby11
Try here, here's almost everything you need to know about Rabbit.
Pby11
Can you tell us a little more about your set.
You've probably MOD1 transmitter?
Which FW version for the Rabbit?
How do you have the receiver connected to the Rabbit FC?(Picture would be good)
How does the led-lights, can you enter the "dormant state"?
Have you already seen these videos?
http://www.youtube.com/watch?v=4NQTLhu9vxM&list=UUl5fI3q_CFUn2SWxEynJenA&index=40
http://www.youtube.com/watch?v=N-1O4vPEc20&list=UUl5fI3q_CFUn2SWxEynJenA&index=39
http://www.youtube.com/watch?v=HcaYq3BMmcg&list=UUl5fI3q_CFUn2SWxEynJenA&index=38
crusher
HI!! I have a mod 2 throttle is on the left.. I have the basic version of the rabbit no gps or anything like that..i have throttle with the 3 wires everything else just signal.. Yes i can get in the breathing state just wont come out of it... I have watched the videos and done everything in them but like in vid 3 where he moves the right stick to the left to get into breathing state mine has to be moved to the right for it to go into breathing.. Here is a you tube vid i did maybe it will help,,, If not and you just pics or something just let me know and ill take some.. Thanks fpr trying to help...
http://www.youtube.com/watch?v=7tO1dR_-rYo
Pby11
Have you done the horizontal calibration?
If not, do it first and try to bind again.
If no change,run pctools for Rabbit.
Set the throttle minimum between 1020-1080.
Also operate each channel on transmitter, observe whether the receiver channel position is right, if not please change flight controller lines, the effective range should be between 1000 ~ 2000, the middle is about 1500.
crusher
Well i got it working finally and you would never guess what was wrong... I had my DX6i setup wrong this whole time.. Reversed the rudder and ailerons and what do ya know it worked.. Thanks for all the help i really appreciate it..
Pby11
If you did run PCTools for Rabbit, you should be observed that the sticks made move in wrong direction.
Glad you got everything working.:tennis:
Now just to fly and enjoy.
