Hood49
Hi Guys,
I have a Fatshark Predator V2 and I would like to increase the rage and the stability of the image. After some research I have found out that I need SMA antennae.
I have come across this antenna on Hobbyking https://www.hobbyking.com/hobbyking...d_5_8ghz_Receiver_Antenna_SMA_LHCP_60mm_.html
Could I use this one for the googles and the Tx? Should be the same no?
Do you think that this is a good antenna to increase range?
Sorry I am new in FPV
Thanks!
Thanks!
