Daniel. Having a little experience with the picloc myself and looking at what picloc toolz is showing you, I would say that you are doing everything right. The quickest way to get it working might be to just use a full rx and plug into the input connections rather than the satellite port. Not the best solution, but maybe it would get it working till George can help.
AUX1 ( for now ) is a toggle function.... ie.. to e-stop.. flick once in a direction, to disable, re-do same movement.
I cannot understand.. now...if you're using separate RX channels or PPM-SUM.
If you're using PPM_SUM, select your AUX1 to take its input from your Channel 7.
If you're using separate RX input, then channel 4 should by default be your AUX1.
Sorry about your issues Daniel. Hopefully someone can assist.
@Holco I assume that you are running the MKS HV-787 in new videos? How are they working for you? Is the potentiometer in that servo 5 Ohm?
Am I right in assuming most of these digi servos use 5Ohm pots?
Thanks gang!
@Daniel.. Make sure your DX8 is working in 11ms framerate ( the fastest mode in Spektrum )
To access this... Power up radio with Roller pressed, then scroll down, and this setting should be in *System*
*if I'm not mistaking*
Before you have any servos connected, you must make sure that the radio commanding is being understood well.
Otherwise, damage can happen ... eg the chicken dance we're seeing in that video... which doesn't help at all !!
