GeorgeM
Yes.. you can still use it, but when panning very fast, you may notice some roll horizon inclination.
In Calibration Tab, bottom item 'Accelerometer Correction', use item 5.
The higher value in this selection, allows the accelerometer to correct quicker.
These values are currently arbitrary, and the 'operation range' of this control will be modified in around 2 firmware updates after the current one.
This will be based on observations I'll receive on the current firmware.
My feeling is that the range of this control will be expanded, to cover different sectors of operation, and will also become remote controlled from an Aux channel.
( it is already remotely variable via Wireless JetiBox connection, and as soon as I publish the XBee tutorial video, also will be able to be adjusted in flight by PiclocToolz ).
But for those who do not want such advantageous features, I will simply add an Aux selection via a drop down menu, or else a proportional knob on our radios ).
I will leave further info to be found from the tutorial setup videos.
**I'll be sending out the replacements as fast as I can.
Laters....
gm>>
Laters....
gm>>
