@hexacop : Lovely test !! This is what is achievable with current firmware (v0.55) and R/C servo motors.
I guess, your Picloc was left alone, doing its work, while you were flying.
@everyone : I am working hard right now to finish building last Piclocs for those reservations I've had. Really sorry for all delays in email replies, etc. Last 2 days were spent on my fulltime job with a
very demanding client. No www time was available.
In next few days, I'll be uploading v0.56 firmware+Toolz, with fixes and some special requests from you guys !. Namely switchable flight modes from AUX1, Startup with options ( eg.. start in safe mode, then when sticks are touched, unit becomes active.. or some similar arrangement ) and also some more enhancements like better horizontal hold with some tunable options.. etc etc.
@mitypsilon - Current firmware does not have failsafe from Picloc's side, and I can perhaps do this in near future. What I was focusing more, was for highest speed and lowest latency in stabilized corrections that Picloc outputs to the servos.
If my loop times remain high enough, I may include this in v0.57 firmware.
But for now... I'd like you to do one test for me..... Connect a headphone or a small PC amplified loudspeaker to the PPM_SUM output of your receiver, and let me 'hear' the output from your RX with radio switched ON and also OFF. You may wish to post it on a youtube video for us. Audio connection goes to RX signal (PPMsum the white or orange wire, and ground ..the black or brown wire).
@Jochen.... Strange occurance... When I set values from my jetibox, I see them change on my PiclocToolz in real time, and when I save either from Jetibox or EEProm Save, the values load again with the last saved.
Is it different for you ?
Re.. Magnetometer switching off by itself, while picloc keeps working, ... is really strange. Perhaps.. it is so strange that I should send you a replacement in return of that one, because I've never seen this happen, and would like to know what's causing it, and conduct some tests.
One last call...Anyone can confirm Spektrum DX7 working well with Picloc-3X ?? No one of my local friends has a DX7i ( that I can borrow) , and I would not like to purchase another Spektrum radio just for testing
![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
15 mins of your precious time over a quick skype call will allow me to hack the spektrum DX7 stream, and make sure that it's working 100%.
@Jesper .. still working on the JR11X inclusion as another option in Picloc-directly-supoprted radios.
Thanks !!
George
