Aeronavics / Droidworx Nic's XM-6 build blog...
nicwilke
Delivery 29 October
nicwilke
Instructions downloaded, printed on digital press, wire bound.
nicwilke
Landing gear assembly. This is way cool. Little tricky to put the thin ply carbon fibre sheet in, but it looks so good with the anodised aluminium orange.
nicwilke
Gear rail assembly. Vibration dampener is really well designed. I suggest you rotate the rubber dampener while inserting into the alloy gear brackets. Makes it easier. You have a choice of 2, yellow (soft) or red (firm). I'm using firm.
hjls3
subscribed. Looks great Nic. I really dig the manual. THanks for sharing. I am currently foaming at the mouth.
nicwilke
Thank you.
It's nearly 1am, so turning it in as I think I break from the manual to do the PDB. Too tired to check.
Taking shape.
nicwilke
Really do not want to stop, but need to be alert tomorrow. See you all in 18 hours (7pm AEDST)
meme
Aah, really nice Nic! Love that Quick release. As far i remember they will not retrofit to the AD6? Am i wrong or Linda told us here, that they will offer the quick release also for the AD Series?
Have fun with it,
meme
nicwilke
There's 2 quick releases, gimbal and land gear. It's incredibly well designed. Not dissimilar to the ADX, but the new stuff is really cool.
Tomorrow, I do some soldering on the PDB, and then continue with the manual.
nicwilke
Great stuff Nic. It is so nice to build something that just goes together...
sleep is soooo over-rated.
Pete
Nina (2yo) woke 'Dadda' at 6am. 'Dadda' went to bed at 2am. LOL.
I'll restart again when Nina goes to bed tonight. My wife is busy building several websites so she's up late in her studio, suits me she is very busy.
nicwilke
Nick... what motors / power / prop setup are you looking at?
Pete
Pete,
My estimated weight, with camera will be 4.4kg. This includes 2 lipo's, gimbal, camera and electrics, so AUW: 4.4kg. Given I am guessing on this, specs of all items calculated together, I can be over by 600g and still get 10 mins flight based on this configuration:
Motors: Tiger MT2814-10 (770kv)
ESC: Turnigy 30A plush (new chip) stock, not flashed.
FC: ZeroUAV YS-Y6 with GPS, and 16 point waypoint, 900mhz Datalink
Battery: 5000mah 4S (35c) x2 Total 10,000mah. I have 10 of these, for 5 10 min flights. I can balance 4 at a time from the car battery.
Gimbal: Photohigher AV130, with Skyline RSGS
Camera: Sony PJ710V (PAL) with Balanced Optical Steadyshot
Props: Have the following to test in hand: Graupner 11x50, Turnigy 13x4.5 Wood, Gemfan 13x4'5s Wood, Gemfan 12x4's Wood
I'd say the Gemfan 12x4's will be the best, safe for full throttle, but the Gemfan and Turnigy 13x4.5's show a little over limit at max throttle, but shouldn't be an issue. The 13's will give me hover at 47% throttle (lets just say half stick) and the 12's boost the throttle to hover to 63%. I think this may be a winner (12's) as I'm on 10mins flight, and chopping the air at higher rpm in my opinion makes the craft a little less suitable to fluctuations in air-pressure (steadier as its higher geared corkscrewing).
The YS-X6 is known to handle all prop sizes really well (favors larger), so I'll test with 13's first, and if its steady, I'll fly about 10 flights with no gimbal to see its stability. If its good, I'll load up the gimbal (so easy on the XM-6) and see how it goes.
The Tigers I have are excellent, and although I'd like the pricier AXIS motors, I simply cant afford to shell out the money for a different logo. I dont see a big enough difference in performance in them to justify the upgrade just yet.
nicwilke
The Droidworx PDB is capable of 8 ESCs, or in this case, 2x 6volt BEC's. One for the Rx, and one for the gimbal.
nicwilke
Motor mounts are smaller than my ADX, and in turn, harder to fit the Tiger MT2814-11. I threw on the spare 6 avrotos as they are identical but never used. Big motors like this, you need a shallower head bolt. The hex bolts supplied have a slightly 'too tall' head on them.
