Boys and Girls!!
The problem has probably been solved.
Today I tested all motors by them self with a RX, and three of them started to go up and down in rpm when they´ve reach about 70-80% throttle. (I guess its the overload protection witch goes active) The funny thing was, that the motor was only pulling about 20 amps from the ESC´s when they started to cut off - its a 30 amp ESC. I tried to reprogram them in all sorts of ways you can, but with the same result :dread:
So now I´ve ordered 9 (One for sparepart) Dualsky 40Amp ESC - XC4018BA from altigator. They should do the job (I hope :tennis
Heres the specs:
Current: 40A (60A in peak)
High modulation rate PWM (10 KHz)
Up to 18 NiCd or Ni-MH cells and from 2 to 6 LiPo cells
BEC (3A) to power the receiver
Thermal protection
Easily programable
Undervoltage protection -> the cutting value can be modified
The minimum value can be programed for motor shutting-off or for low RPM mode
Break activating/desactivating possibility
Optimised advance timing
Secured activation elimination an eventual accidental motor start
Soft startup allows to avoid mechanical overload
Automating shut-off 4 seconds after signal missing/bad signal
Controlled by microprocessor of the most advanced technology
Possibility to change the rotation direction without disconnecting
Weight: 30 grams
