New Luanch RTK on CeBIT 2017
TopXGun
DGPS RECEIVER Air–Standard is designed specially for the high-precision flight of the UVAs. It is compatible with TI and T1-A to make the UVAs achieve the cm-level precise position. We're going to launch it at 2017 Cebit!We're going to launch it at 2017 Cebit!
The internal board of DGPS RECEIVER Air–Standard adopts GPS+BDS dual-system-five-frequency high dynamic calculating engine which supports the super long baseline E-RTK measurement. The frequencies received by the board include BDS B1/B2/B3 and GPS L1/L2. It supports GPS/BDS single system independent position and GPS+BDS joint system position, adapted to more severe and longer-distance position environment.
Main Parameter
Tracking SignalGPS:L1C/A,L1P,L2P BDS:B1I,B2I,B3I
First position timeCold start:<50s Hot start:<45s
Recapture SignalL1/B1<1.5s(fast)<3s(ordinary)
Position Precision
Single-point precision: 1.5m
Fixed solution precision: Horizontal 0.01m Vertical 0.02m
Floating solution precision: 0.4m
RTK Performance
Initialization time<10s(baseline length <20km)
Initialization credibility>99.99%
Data Rate5Hz
Physical size and electrical characteristics
Voltage+5V±5%VDC
Power consumption2.8w
Weight95g
Size112mm*52mm*17.5mm
Environmental indicators
Operating temperature-40 ℃ ~+80 ℃
Storage temperature-55 ℃ ~+95 ℃
Cebit: March 20-24, 2017
http://www.cebit.de/en/
Deutsche Messe AG
MessegelAnde 1, Hannover, 30521
Shanghai TopXGun Robotics Co., Ltd.
Booth:H006 G54
