Here is my first flight test...Please try and ignore the absolutely horrible video quality my wife's Sony Cybershot produced. I still need to buy my Nex-5n. In this video I tried to make very extreme roll and pitch manuvers over and over trying to get the gimbal to hit its travel limits.
Problems I see:
1) I have a "bounce" on roll. Since I dont see this bounce when I preform "mirror video testing" holding the gimbal firmly in my hands, I believe this is mostly caused by not enough rigidity on my vertical mounted "roll assembly". I am getting torsional "twishing" in this roll structure. This is causing a resonance type "bouncing" as wind and other external forces hit the roll assembly. Then as the structure bounces the servos try and compensate for it and further degrades the footage. To correct this I plan to add a couple carbon bracing tubes running from the lower corners of my "roll assembly" at an angle up to the rear edges of my gimbal assembly underside. Sort of similar to how RC heli's brace their tail boom. This should increase my torsional stiffness enough to stop this twisting. Ideally I would use slightly thicker plate to help with this but I am really not wanting to cut new plate.
2) When I make roll manuvers with my hex the roll axis doesn't level exactly with the horizon. Its good, but slightly off by what looks like 3 to 5 degrees. I am thinking this may be the roll "scaling" setting within my hoverflygimbal. Looks like I need to increase it some so the gimbal corrects at a higher angle.
Things I am happy with:
1) Tilt. Tilt looks to be almost dead on. I have no bounce in tilt. Also the servo/gimbal/controller seems to be doing an excellent job of keeping the camera correctly stabilized on that axis. The movement looks very very smooth in the footage. Few minor adjustments and I think my tilt is golden.
2)
Overall roll movement smoothness looks good. If you ignore the bouncing I am getting in roll and just focus on the overall movement that axis is making it looks very smooth.
3) Gimbal travel looks good. In the video I took my hex to the limits of roll/tilt transition I felt safe with. Somewhere around 30 degrees in either direction (60 total per axis). The gimbal didn't seem to ever hit any mechanical stops so my travel looks good. This only holds true for the flight characteristics of my Hex while in "GPS" flight mode. If I clicked my flight mode over to manual then I am sure I could bottom out the gimbal. But, I don't fly in manual for aerial video anyways!
Another thing that I believe will help things out is my vibration dampning. I don't feel my design if sufficient and that I am sending vibrations to my camera. I am already in the works of beefing up vibration dampning.
http://www.youtube.com/watch?v=8g7kVVBmzLY
