All,
I need some help with trying to get better flight times for my DJI F550.
I've searched the forums and found a ton of different threads and since I'm new I'm still learning so please go easy on me. If I forget to post a piece of critical information just let me know.
DJI F550 Stock Motors using DJI 10" props
Naza with GPS
TX - Spektrum DX7S
RX - Spektrum AR8000
Telemetry - Spektrum TM1000
Flame Gear XT landing gear and 2 axis gimbal camera mount
Turnigy 5000mah 3S pack 25-35c weight is 412g (I have 3 packs)
Gopro HD2
All up weight is 2132g
I get about 10 minutes of flight time until my lipo hits 10.5v
I'd like to get more flight time and from what I've read I can swap out the motors and props.
I just ordered 10" Graupner props and they should be here in the next week or two since they're coming from the UK.
If motors are needed, what suggestions do you have for motors that will give me better flight times with an all up weight of 2132g that will also work with the Graupners and fit the stock hole pattern for the DJI F550 arms?
Would going to 4S be better for my needs?
I plan on adding FPV at some point so the weight will increase a bit
I don't do much stunt flying but more video and photography with slow flights and hovering.
I tried to use Ecalc but couldn't find the specs that I needed for the DJI motors that it was asking for.
Any other suggestions you may have for better flight time would be greatly appreciated.
Thanks,
Xnavyguy
Naza with GPS
TX - Spektrum DX7S
Gopro HD2
Thanks,
Xnavyguy
