15crewdawg
I have a strange issue going on here.
This is a TBS Disco on 4S, T-Motor 2216-11 900kv, Maytech Eagle 30A SimonK ESCs, Spektrum AR7200, DX7.
I swapped out the stock DJI 30A ESCs with the Maytechs, performed throttle calibration of the ESCs, re-calibrated the TX through the NAZA assistant software. Everything shows normal in the assistant.
Here's the problem. When plugged straight into the RX the motors spin up perfectly and respond quickly.
When I plug them into the NAZA the motors do not respond to the CSC startup command. If I move the throttle past 50% the motors start at higher than idle speed but if I move the throttle barely below 50% they shut down. And the motors don't seem to go full power with 100% throttle. If I leave the throttle at 50%, like in a hover, 2 (or sometimes 3) motors will stop after a short time. (Almost like after a landing) If I move the quad the motors will restart, but once I set it back level the motors stop again.This happens in Atti and GPS.
In manual, the motors still don't respond to CSC but will start with raised throttle and seem to operate normally with good throttle response speed and range.
When throttle is dropped to 0% 3 of the motors shut down but motor 3 keeps running for 15-20 seconds. This happens regardless of flight mode.
What am I missing here?
Does the NAZA V2 have issues with these ESCs?
