Daniel-Geneva
Any idea guys !!!
your battery voltage is dropping lower than expected levels. might be a low c rated battery (25c or lower) or it's damaged from the shelf (seen that alot with big brands) to
When you land after your claimed flight times it's suppose to be flown, what is the voltage of the pack resting? if you fly it till this cuts off the way it is setup now, whats the batteries resting voltage? only way other than through real time telemetry that i can think of to get you a close number to try
that is perfect, any idea what it is when your actually flying?
where the packs ever over discharged? are all the cells showing the same voltage?
