RunnerDuck
Super
Its always the most simple mistake that you think you've checked! At least the next chunk of work is fun.
From your screen shots I would quickly look at your volt settings if you want a normal flight time...
3.6 v per cell for s1 and a loss will be around 0.4 or so. I set the second self landing voltage as low as it will go - 9.9. I'd rather wreck a battery over have it self land somewhere unsafe.
Thanks Rotorfreek!
I have a question regarding your comments. I noticed during my first flight that the NAZA led started flashing red at about two minutes in. Typically that would mean "Low Battery" but when I put it on the bench it measured 12.1 which should have been fine.
Would changing the settings as you suggested fix that?
