Naza GPS compass calibration
hexcopter
same thing I enable flap sw . f mode:inh . in naza assi same thing at 0 highlight A , 0 to 1 show failsafe at bottom right corner , and 1 to 2 show failsafe at bottom right corner ,
hexcopter
oh ok , JR 9503 is the good one. and now I don't known how to make the sw hightlight A,GPS,M , I try both F-mode and Flap sw they can't . so sad
glacier51
f-mode sw
T-Ed/Hex:
Well, you guys are doing something I'm unable to and that's why I ended up on the FLAP sw. I can't get the fmode switch to accept any change in the Switch Select menu on the DX8. That's where I wanted to be as well.
glacier51
f-mode sw
Geez, well that didn't take much effort.
When I tried to activate the f-mode sw, it wouldn't come out of INH, and this is what I just discovered minutes ago, apparently because all the other (receiver?) positions were taken.
If I put FLAP sw into INH, that freed up AUX1, which I could then assign to the f-mode sw.
glacier51
>I try to get 3 position sw for gps-a-m but I can't .
What switch are you trying to use? Did you get my file showing how to setup the FLAP switch for use as the 3 position Flight Control switch?
hexcopter
thank you every one for help , I get sd card from some one and set up with dx8 , it work well , but still don't known what reason no highlight for ATT-GPS-M
Hey Sev
Well done for publishing that trick of setting the control switch to GPS/Attitude /manual, and not GPS/Attitude/Fail-Safe to get the GPS to calibrate. I was also tearing my hair out trying the get that solid yellow display so I could get it to calibrate, and it worked first time after I reset the control switch range.
I will be adding that to the MRC tips and tricks pages of my web site at www.chopperaddict.co.uk so other will be able to find it more easily.
Ian
