if you haven't flown your heli yet and this is a first build meant for first flights I'd recommend you not set up the failsafe mode or any of the other advanced functions. i'm in the process of writing a review article for the NAZA-M V2 and, after spending a lot of time with the manual, I'm more and more convinced that the advanced functions have a big potential for causing more problems than they might fix. In fact without them I think a new pilot is going to be more careful and take things more slowly giving them time to get settled in and really learn how their stuff works. then when they decide to try the advanced functions they'll be less likely to panic if FailSafe does trigger or if they have to switch to MANUAL mode to stop a bad event from getting worse.
the advanced functions (some of them at least) are nice to have but they really require the pilot to know what to expect as they take time to play out and do what they're intended to do. some things though, like dropping below the required satellite count, can cause the functions to just stop working without warning other than a change of the flashing LED but does anyone really have all of the possible LED combinations memorized?
just a though, keep it simple at first.
bart
bart
