Just got a reply email from GotHeli Rc......."believes the button is to reset the board"......
Got Heli's responses to questions is outstanding!
You have to adjust the positioning of the camera when you change the lens in order to maintain balance. When you use the 18-55 lens, the whole camera sits back further in the gimbal and there is plenty of space to use the HDMI cable mentioned. With the 16mm lens, the HDMI plug gets in the way of the gimbal and you have to make the modification mentioned. I attempted them myself since I use the 16mm, but even after being extremely careful with the mod, the cable wasn't able to handle it and stopped working. It's a shame that this gimbal isn't just a few mm wider so that this issue would go away on it's own. I love my gimbal, but this is the one drawback in my opinion. I have opted to use a small FPV camera mounted ontop of my lens instead of the HDMI output. With this approach, you get the added benefit of not needing an HDMI converter onboard adding more weight to the build.
I have one on the way, that I will use on my 6s S-800 hexa. I will need a separate lipo for the gimbal, what voltage is working best? Are the initial settings for 3s or 4s? Has anyone tried using a BEC to power the gimbal motors?
Thanks,
Bill Davenport
AMA 28141
Anyone?
Humm, I have done mine and it has been working fine.... I did shoot a bit of hot glue over it and heat shrink it though. Everything seem to be pretty solid. Personally I would preferred it this way, I wouldn't want a giant plug or 90degree converter. It would be adding about 10mm to use a 90degree adapter and 20mm to use a normal plug. If you really want it, I can do the surgery for you.![]()
i understand that the mini hdmi cable will grab the video from the camera and send it where? what fpv system comes with a full sized hdmi input? extremely confused here haha
Quick question
Has anyone tried the Sony HX30V in the vx5n gimbal? Trying to find a good gimbal
The new firmware will have Silent mode.
