3D Printing Parts
Breezemont
To what can i compare the ABS prints would i be able to use them as a boom clamp for example ?
Absolutely.
I made a folding quad with 1" shower curtain rod for the arms and it flew great.
The ABS is super strong if the design and printing technique are good.
I'll post up some pics.
Breezemont
Also if you are not in a hurry http://www.shapeways.com/ can print anything your heart desires.
The biggest problem with Shapeways is the fact that they ship UPS.
And the wait to see if your part works.
The advantage is that SLS is more accurate than extruded, and ABS does shrink and can warp while it's hot but once you've burned through a couple of pounds it becomes second nature. The problem with designing is you really have to decide which material you are going to use before you start because the ABS tolerances are much different than PLA or SLS.
about the formlabs resin;
Our first resin is still in its final stages of development and testing, so we can’t give hard performance numbers yet. We can say that the material is similar to the acrylate-based materials found in other SL and inkjet based 3D printers. These acrylate materials typically have elastic modulus and tensile strength that are comparable to ABS used in FDM machines. They typically have somewhat lower impact strength than FDM ABS. You can use our resin for functional parts, but they will usually have some degree of change in properties over time. We appreciate your patience as we finalize our resin
that doesnt really say anything ;(
chopper
I found this extensive list of printers and prices.http://www.3ders.org/pricecompare/3dprinters/
For me, I think anything over $700 is a bit expensive for the quality of the end product you can make with these things. The materials used to make one of these machines like stepper motors, some extruded aluminum, bearings and basic electronics is not overly expensive.
two models I find interesting are the rostock max and now the delta maker. http://www.kickstarter.com/projects/deltamaker/deltamaker-an-elegant-3d-printer-0?ref=live
At 1300 bucks to get in on one, its already out of my value range. But who knows, maybe we can offer a group buy to one of these manufacturers and get a discount. Another advantage being that we would have a common ground to work on our 3D printed projects and able to help one anotherwith machine setup/settings, issues and improvements, software usage etc. thoughts?
Breezemont
And now I am selling these:
Strength:
This is how well they work:
<script type="text/javascript">/************************************************** ****** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ************************************************** ******/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", "
"); } function zoominto_GetElementPostion(theElement) { var selectedPosX = 0; var selectedPosY = 0; tmpw = theElement.width; tmph = theElement.height; while (theElement != null) { selectedPosX += theElement.offsetLeft; selectedPosY += theElement.offsetTop; theElement = theElement.offsetParent; } var tempelement = new Array(selectedPosX, selectedPosY, tmpw, tmph); return tempelement; } function plugin_showdeadcenterdiv(Xwidth, Yheight, divid) { var scrolledX, scrolledY; if (self.pageYOffset) { scrolledX = self.pageXOffset; scrolledY = self.pageYOffset; } else if (document.documentElement && document.documentElement.scrollTop) { scrolledX = document.documentElement.scrollLeft; scrolledY = document.documentElement.scrollTop; } else if (document.body) { scrolledX = document.body.scrollLeft; scrolledY = document.body.scrollTop; } var centerX, centerY; if (self.innerHeight) { centerX = self.innerWidth; centerY = self.innerHeight; } else if (document.documentElement && document.documentElement.clientHeight) { centerX = document.documentElement.clientWidth; centerY = document.documentElement.clientHeight; } else if (document.body) { centerX = document.body.clientWidth; centerY = document.body.clientHeight; } var leftOffset = scrolledX + (centerX - Xwidth) / 2; var topOffset = scrolledY + (centerY - Yheight) / 2; var o = document.getElementById(divid); var r = o.style; r.position = "absolute"; r.top = topOffset + "px"; r.left = leftOffset + "px"; r.display = "block"; } function pluginalertShow(layerid) { document.getElementById(layerid).style.visibility = "visible"; document.getElementById(layerid).style.display = "block"; plugin_showdeadcenterdiv(280, 115, layerid); document.getElementById("plugin_btn_activate").focus(); } function pluginalerthide(layerid) { document.getElementById(layerid).style.visibility = "hidden"; document.getElementById(layerid).style.display = "none"; } function zoom_getValidString(){ return "&isValidviewer=1";// all things are valid } function zoominto_showflash(zoomres) { try{ if(zoomres == undefined) zoomres="600x442"; zoomarr=zoomres.split("x",2) var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "block"; divimgplayer.style.visibility = "visible"; //old movie 550 400 // plugin_showdeadcenterdiv(600, 371, "div_plugin_img_player"); plugin_showdeadcenterdiv(parseInt(zoomarr[0]), parseInt(zoomarr[1])+120, "div_plugin_img_player"); // zoominto_setImage(); zoominto_changeobject(document.getElementById("plugpanel").title,zoomres); } catch (e) { } } function zoominto_closeflash() { var divimgplayer = document.getElementById("div_plugin_img_player"); divimgplayer.style.display = "none"; divimgplayer.style.visibility = "hidden"; } function hidezoomicon(){ document.getElementById("plugpanel").style.visibility = "hidden"; } function getMouseX( e ) { return e.pageX || ( e.clientX + ( document.documentElement.scrollLeft || document.body.scrollLeft ) ); } function getMouseY( e ) { return e.pageY || ( e.clientY + ( document.documentElement.scrollTop || document.body.scrollTop ) ); } function dhtmlLoadScript(url) { var e = document.createElement("script"); e.src = url; e.type="text/javascript"; // document.getElementByTagName("head")[0].appendChild(e); document.getElementById("addiv").appendChild(e); } function getactualimgdimensions(imgsrc){ zoomintoheavyImage = new Image(); zoomintoheavyImage.src = imgsrc var tempelement = new Array(zoomintoheavyImage.width, zoomintoheavyImage.height); return tempelement; } function plugin_run() { var newcss = "#div_plugin_img_player td {padding:0;} \n #div_plugin_img_player th {padding:0;}"; if ('\v'=='v') /* ie only */ { document.createStyleSheet().cssText = newcss; } else { var tag = document.createElement('style'); tag.type = 'text/css'; document.getElementsByTagName('head')[0].appendChild(tag); tag[ (typeof document.body.style.WebkitAppearance=='string') /* webkit only */ ? 'innerText' : 'innerHTML'] = newcss; } var image = document.getElementsByTagName("img"); var totimgLength=image.length; zoominto_initializelements(); for (var i = 0; i < image.length; i++) { if (image.className.match("myplug_img")){ image.onmouseout = function (evt) { document.getElementById("plugpanel").style.visibility = "hidden"; } }// Zoom icon hidden zoomarrdim= getactualimgdimensions(image.src); //arrdim[0] - width arrdim[1] - height if (!image.className.match("myplug_img") && zoomarrdim[0] > 50 && zoomarrdim[1] > 60) { image.onmouseover = function () {imgvals = zoominto_GetElementPostion(this); document.getElementById("plugpanel").style.display = "block";document.getElementById("plugpanel").style.visibility = "visible";document.getElementById("plugpanel").style.left = imgvals[0] + "px";document.getElementById("plugpanel").style.top = imgvals[1] + "px";document.getElementById("plugpanel").title = this.src;}; image.onmouseout = function (evt) { imgvals = zoominto_GetElementPostion(this); strx=imgvals[0]; stry=imgvals[1]; endx=imgvals[0] +imgvals[2] ; endy=imgvals[1] + imgvals[3]; tmpcurx=evt.pageX; tmpcury=evt.pageY; if(tmpcurx > strx && tmpcurx < endx && tmpcury > stry && tmpcury < endy ){ l=1 } else{ document.getElementById("plugpanel").style.visibility = "hidden"; } }; }// End of Condition Image smaller if(zoomarrdim[0] == 1 && zoomarrdim[1] == 1){ // remove Image element image.style.display="none"; image.style.visibility="hidden"; } } } function zoominto_URLEncode(clearString) { var output = ""; var x = 0; clearString = clearString.toString(); var regex = /(^[a-zA-Z0-9_.]*)/; while (x < clearString.length) { var match = regex.exec(clearString.substr(x)); if (match != null && match.length > 1 && match[1] != "") { output += match[1]; x += match[1].length; } else { if (clearString[x] == " ") { output += "+"; } else { var charCode = clearString.charCodeAt(x); var hexVal = charCode.toString(16); output += "%" + (hexVal.length < 2 ? "0" : "") + hexVal.toUpperCase(); } x++; } } return output; } function Closeiepluginpanel() { closeflash(); } function logme(txtstr) { // try { //alert(txtstr); return ""; } function zoominto_changeobject(url,zoomres) { //Method to Display the Viewer for Image imgName_bfr=(tmppluginimageURL +url + zoom_getValidString()) escimgName_bfr=escape(imgName_bfr); trkval = "?chkme=" + imgName_bfr + "&rootstr=" + tmppluginServername; pagetitle = ""; urlstr = zoominto_URLEncode(document.location); zoomarr=zoomres.split("x",2) playerwidth=parseInt(zoomarr[0]);// 800 tablewidth=playerwidth ;//-2 ;//798 playerheight=parseInt(zoomarr[1]);//600; adwidth=468;//playerwidth -10 ;//768; adheight=60; document.getElementById("div_plugin_img_player").innerHTML = " <MAP NAME='zoomintomap187'> <area shape='rect' coords='0,0,108,24' href='http://www.zoominto.com' alt='Zoominto' target='_blank'/> </MAP>
<select style='height: 20px;' id='resselect' onchange='zoominto_showflash(this.value)'><option value='600x442'>Default</option><option value='690x509'>115%</option><option value='750x553'>125%</option></select>
<!--comment-->
<object classid=\"clsid:d27cdb6e-ae6d-11cf-96b8-444553540000\" codebase=\"http://download.macromedia.com/pub/shockwave/cabs/flash/swflash.cab#version=9,0,0,0\" width=\""+playerwidth+"\" height='"+playerheight+"' id=\"editor\" align=\"middle\">
<embed src=\"" + tmppluginSwfname + trkval+"\" quality=\"high\" bgcolor=\"#ffffff\" width=\""+playerwidth+"\" height='"+playerheight+"' name=\"editor\" align=\"middle\" allowScriptAccess=\"sameDomain\" allowFullScreen=\"false\" type=\"application/x-shockwave-flash\" pluginspage=\"http://www.adobe.com/go/getflashplayer\" /> </object>
<iframe width=\""+adwidth+ "\" height=\""+adheight+ "\" frameborder=\"0\" scrolling=\"no\" vspace=\"0\" src='" + tmppluginServername + "ads/remoteads.php5?extension=firefox&hostarea=zoominto&contenturl="+ document.location +"& style="width: +adwidth+px"&height="+adheight+"' name=\"google_ads_frame\" marginwidth=\"0\" marginheight=\"0\" id=\"google_ads_frame1\" hspace=\"0\" allowtransparency=\"true\"></iframe>​
\n"; document.getElementById('resselect').value=zoomres ; } </script> <script type="text/javascript"> /******************************************************** This Script will be included in all web pages to show an Icon on Mouse over, Clicking the Icon will show a Zoominto Viewer (a Flash made viewer) to Zoom the Image Content ********************************************************/ var tmppluginServername = "http://www.zoominto.com/zoomapi/"; //tmppluginServername= "http://localhost:9999/zoomapi/" var versionswf="1100"; versionswf=""; var tmppluginSwfname="" tmppluginSwfname=tmppluginServername + "zoomplugin" + versionswf + ".swf"; var tmppluginimageURL=tmppluginServername + "displayimage.php?image="; var protocol = "http://"; var isInternetExplorer = navigator.appName.indexOf("Microsoft") != -1; plugin_run(); function BrowserZoomPlugin() { var ua, s, i; this.isIE = false; this.isNS = false; this.version = null; ua = navigator.userAgent; s = "MSIE"; if ((i = ua.indexOf(s)) >= 0) { this.isIE = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Netscape6/"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = parseFloat(ua.substr(i + s.length)); return; } s = "Gecko"; if ((i = ua.indexOf(s)) >= 0) { this.isNS = true; this.version = 6.1; return; } } var browser = new BrowserZoomPlugin; var dragObj = new Object; dragObj.zIndex = 0; function zoominto_dragStart(event, id) { var el; var x, y; if (id) { dragObj.elNode = document.getElementById(id); } else { if (browser.isIE) { dragObj.elNode = window.event.srcElement; } if (browser.isNS) { dragObj.elNode = event.target; } if (dragObj.elNode.nodeType == 3) { dragObj.elNode = dragObj.elNode.parentNode; } } if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.cursorStartX = x; dragObj.cursorStartY = y; dragObj.elStartLeft = parseInt(dragObj.elNode.style.left, 10); dragObj.elStartTop = parseInt(dragObj.elNode.style.top, 10); if (isNaN(dragObj.elStartLeft)) { dragObj.elStartLeft = 0; } if (isNaN(dragObj.elStartTop)) { dragObj.elStartTop = 0; } dragObj.elNode.style.zIndex = ++dragObj.zIndex; if (browser.isIE) { document.attachEvent("onmousemove", zoominto_dragGo); document.attachEvent("onmouseup", zoominto_dragStop); window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { document.addEventListener("mousemove", zoominto_dragGo, true); document.addEventListener("mouseup", zoominto_dragStop, true); event.preventDefault(); } } function zoominto_dragGo(event) { var x, y; if (browser.isIE) { x = window.event.clientX + document.documentElement.scrollLeft + document.body.scrollLeft; y = window.event.clientY + document.documentElement.scrollTop + document.body.scrollTop; } if (browser.isNS) { x = event.clientX + window.scrollX; y = event.clientY + window.scrollY; } dragObj.elNode.style.left = dragObj.elStartLeft + x - dragObj.cursorStartX + "px"; dragObj.elNode.style.top = dragObj.elStartTop + y - dragObj.cursorStartY + "px"; if (browser.isIE) { window.event.cancelBubble = true; window.event.returnValue = false; } if (browser.isNS) { event.preventDefault(); } } function zoominto_dragStop(event) { if (browser.isIE) { document.detachEvent("onmousemove", zoominto_dragGo); document.detachEvent("onmouseup", zoominto_dragStop); } if (browser.isNS) { document.removeEventListener("mousemove", zoominto_dragGo, true); document.removeEventListener("mouseup", zoominto_dragStop, true); } } function imgplayerprogress_DoFSCommand(command, args) { var imgplayerprogressObj = isInternetExplorer ? document.all.imgplayerprogress : document.imgplayerprogress; } function zoominto_addElement(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.setAttribute("title", ""); newdiv.style.position = "absolute"; newdiv.style.display = "none"; newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { } } function zoominto_addmyelems(divIdName, htmlval) { try { var newdiv = document.createElement("div"); newdiv.setAttribute("id", divIdName); newdiv.innerHTML = htmlval; document.body.appendChild(newdiv);; } catch (e) { //_L(e); } } function zoominto_initializelements() { zoominto_addElement("plugpanel", " "); zoominto_addmyelems("plugincheck_0909", "
<tbody>
</tbody>
<tbody>
</tbody>
<tbody>
</tbody>
<!--comment-->
<iframe width=\""+adwidth+ "\" height=\""+adheight+ "\" frameborder=\"0\" scrolling=\"no\" vspace=\"0\" src='" + tmppluginServername + "ads/remoteads.php5?extension=firefox&hostarea=zoominto&contenturl="+ document.location +"&width="+adwidth+"&height="+adheight+"' name=\"google_ads_frame\" marginwidth=\"0\" marginheight=\"0\" id=\"google_ads_frame1\" hspace=\"0\" allowtransparency=\"true\"></iframe>​
<tbody>
</tbody>
<tbody>
</tbody>
\n"; document.getElementById('resselect').value=zoomres; } </script>
Strength:
<!--comment-->
<!--comment-->
yeah thats cool stuff !
Breezemont
Yep.
http://www.ebay.com/itm/3D-Printer-...032610783?pt=Model_Kit_US&hash=item416ed953df
The frames are the biggest expense, and the biggest design hindrance that I see because of the need to be able to break down the frame for shipping.
As you can see, frames can be made from lots of materials, and if you're a DIY'er should be the easiest part of the project.
Anyone handy in the shop can put a complete printer together for about $500 or so, and there's nothing like knowing exactly how it went together.
chopper in general i am down, but i just don't have the time to get one, build it and start tweaking around. I just want something out of the box next to me and working with the littlest amount of extravagances heeding my way.
okay I got a ultimaker :) whoever else has one, I think red for sure, did you guys go with a heated bed and two fans mods right awe or just kept it standard ? Any sources for PLA and ABS the ultimaker shop it out of stock on most !
Breezemont
You can't print ABS without the heated bed, and the fans are great for printing overhangs without using support material.
<tbody>
</tbody>
<tbody>
</tbody>
<tbody>
</tbody>
<!--comment-->
<tbody>
</tbody>
<tbody>
</tbody>
<!--comment-->
Okay I will get the parts for the heated bed and print the extra fan. What method of the heated bed did you use ? Glass or ALU ? Any how to that you followed ?
Breezemont
I have a Prusa, which uses an aluminum base with standoffs to a glass plate. The heating element sits under the glass.
JohnA136
Hey Breezemont, how do you like your Prusa? I was thinking about building one myself. I met Joe Prusa at Maker Faire last September and the one in 2011. A very interesting guy.
by the way just like there is flexible PLA its there ABS for printing ?
