Hood49
Hi Guys,
I am a but stuck here. I hope you can help me.
Over the last few weeks I have been building my Mini quad.
Chinese carbon frame
Emax 12 amp ESC
RCX 2400 kv motors (1804)
3S Lipo
CC3D board
Graupner GR-12 receiver (6 channel)
Made my own wire harness and there is juice in all wires.
With the configuration wizard I have been going through the configuration of the CC3D board. Everything works well:
=>motors are spinning in the right direction
=>Calibrated the motors and ESC's
=>Sequence of the motors are setup well
=>Setup PIBank
=>Attitude set
Radio is setup and all sticks are in the good direction.
PROBLEM:
Before taking off the motors spin well. When adding some throttle it wants to take off. But as soon as it lifts off it goes crazy and flips over (I am speaking about 10cm from the ground)
Look like something serious is going wrong here.
When I want to start again I can see that intermittently one motor does not turn, only when I add more throttle it starts turning. But I can see that it is not going as fast as the others. (I have calibrated them with the Openpilot Wizard). When I disconnect the battery (and reset the CC3D) all motors seem to start up together again (weird)
So I am thinking of these possible problems:
1. Motors are crap
2. ESC is not working as they should
3. Wiring issue? (would be surprised, I checked everything)
Any idea what I can check? Did one of your experience this before.
Many thanks in advance fro your input!
Emax 12 amp ESC
3S Lipo
CC3D board
=>Setup PIBank
=>Attitude set
PROBLEM:
1. Motors are crap
