Matts PVC T-QUAD
mattsPVC
DIY Wire Rope Isolators
Thought I would have a tinker with Wire Rope Isolators.
After a number of prototypes this is what I have come up with so far.
Using:
1x 40mm PVC pipe cap. Cut down to 1cm.
1x 50mm PVC pipe cap. Cut down to 1cm.
1x length of 1.1mm Wire Rope. The same cable they use on bikes for changing gears.
I tried 1.6mm and 2mm wire rope but found it too stiff for the weight of the Gopro.
I will post a video shortly with the results.
View attachment 5567View attachment 5566View attachment 5568View attachment 5565View attachment 5564View attachment 5574View attachment 5563
View attachment 5569View attachment 5570View attachment 5571View attachment 5572View attachment 5575View attachment 5576View attachment 5573
tstrike
pendejo grande
WOW!!! It says a lot that you're hitting it out of the park with sprinkler parts and a steady hand. Well done sir, well done indeed. Was this on your hex or quad?
mattsPVC
Thanks.
I used my new prototype T-Quad on that film. I started a new build thread on it here
mattsPVC
New Version
My new light weight PVC T-Quad.
I have moved the battery to the top, and the flight controller to the middle. To get the CG up higher.
You have to cut out the middle with a dremel to get every thing to fit. Structurally it still feels very strong. Will find out when I crash it next.
Still with 20mm PVC pipe and T-adapters.
Arms are 20cm, Motor to Motor is 480mm.
Hardware:
Flight Controller: DJI NAZA Gains: 125 125 125 90, attitude 95 95.
ESC: CarbonBird 18a, these a super compact and fit in the 20mm PVC arms.
Motors: Turnigy NTM 28-26 1200kv
Prop adapters: NTM prop drive 28 series
Propellers: Gemfan 9x4.7 (Nylon/Carbon Mix)
Battery: Zippy Compact 3s 4000mah 25c
Weight:
With FPV gear (Without battery) 903 grams.
With FPV gear (With battery) 1190 grams. Hover time 15 minutes.
With FPV gear & Gopro camera (Without battery) 1134 grams
With FPV gear & Gopro camera (With battery) 1420 grams. Hover time 12 minutes, Flight time 8 minutes.
View attachment 6242View attachment 6243View attachment 6244View attachment 6245View attachment 6246View attachment 6247View attachment 6248View attachment 6249
mattsPVC
Gopro Rotor Shade
This helped me eliminate the horizontal lines you get when the sun shines through the propellers onto the Gopro Lens.
It can only be used when the lens angle is set to "Medium" though.
I used the bottom of a plastic container to make it.
View attachment 6285View attachment 6286View attachment 6287
mattsPVC
So after carting up all my gear to the top of the mountain. I found that I forgot to bring my video reciever power cable. So had to film LOS on this footage. Next years will be better.
Keeping my batteries warm prior to use made a big difference in flight time. I stored them in a insulated fabric wine bottle cooler.
mattsPVC
Gopro Rotor Shade Test Video
A short video showing with and without the "Rotor Shade"
Hardware:
Weight:
View attachment 8218View attachment 8219View attachment 8220View attachment 8221View attachment 8222View attachment 8223View attachment 8224View attachment 8225
Great job Matt, at the end of your test, which version and setup do you recommend ?
mattsPVC
My latest version seems to be working well. Putting the battery on the top has made it more stable. I think it is giving the flight controller an easer job, with less weight hanging from the bottom.
Also upping my gains has help too. They were on 95 95 90 90.
I'm happy with my current setup. 8 minute flight times is plenty for what I want to do.
Millsy
Hi Matt,
Awesome build.
Might be just what i should start with as i'm a total newbi to multi's or any thing that flies in fact.
A mate has me hooked on getting/building one. he's is amazing but quite expensive.
If i was to copy your build, what would it cost?
Cheers
Millsy
mattsPVC
Hi Matt,
Awesome build.
Cheers
Millsy
To get a Basic "Line of Sight" PVC T-Quad it would cost a minimum of:
Dji Naza Flight controller $250
ESC Speed controllers x4 @$15 each = $60
Motors x4 @$15 each = $60
Propellers x12 @$2 each =$24
Power distribution board x1 =$7
Basic radio $70
Batteries x3 @$25 each = $75
Battery charger $50
Materials to build PVC T-quad $50
Total approx $650
To add FPV equipment it would cost approx:
Fatshark goggles $300
FPV camera $70
FPV transmitter $40
FPV receiver $40
Total approx: $450
So all up approx: $1100
