Man that's tight.....S800
hazardpro
Hi all
Trying to hook up a 'fully loaded' S800 and its pretty damn tight, does anyone have any pics of where they have positioned their gear on the S800
What I have;
2 x Aurora 9 receivers
Wookong M (and associate components)
OSD
Video link x 2
So far I have managed to get the receivers, Wookong bits inside the frame... and its packed
OSD, Video links & datalink will have to go on top I suppose.
Any pics of others set ups would be gratefully received! :)
Doug
BorisS
Crucial for me was also the fast disconnect front he landdinger gear by unplugging only a couple cables.
Three things to unplug, power to zenmuse and two times Can-bus. Can-bus from the GCU and the LED.
OSD in front between the center plates, Data link and RX on the arms. But i would like to but the RX under the center plate at some point like recommended by Sidney.
Only CGU and Zenmuse RX on the Gimbal
Can-bus hub used although i don't really need it. But just make the placement easier.
View attachment 8073View attachment 8072View attachment 8074
Boris
Tahoe Ed
I have mine mounted on two bridges between the LG frame. I have one receiver mounted on M3 arm and the other mounted on M6 arm with the satellite on the leg. The vTx is mounted on a leg. This was the mounting point that DJI has used on several of their demos. Here is a picture that may help you.
Tahoe Ed
I do and it works very well. Mine is set up for two person operation so the camera guy has the OSD info through the goggles. If there is a problem, he can tell me. I am flying LOS so for the most part I don't care.
hazardpro
Placing the wkm where they suggest means it's virtually impossible to plug in the USB/data cable?
Can you go via the USB plug on the OSD unit?
Doug
