Greg
Nope,dont need more channels.7 Are fine.(you really won't need to rebind unless you need the other 8 analog channel out puts)I am still unclear.Why doesnt he mention anything about binding?.I dont think I asked the question properly.Will binding like you said make ch 5 mode?,my sticks work fine.you want to bind in mode 5. It's the one listed in the x8r manual with 2 jumpers on Channels 1-2 and 3-4. Then you need to make the CH selection in the Taranis 1-16. That option is on the first screen in the older companion 9X or right above the BIND function in the Taranis screen.
If you have the sticks working correctly in the Naza assistant - you really won't need to rebind unless you need the other 8 analog channel out puts.
It just makes sense to me.Why skip over 2 unused channels.I only need 5 channels.I got it sorted by using conventional wiring.I had sbus problems with my ET vector aswell and switched to pwm.I will get a spectrum receiver when I figure out which one to get as they dont have problems with sbus like the taranis does.No it won't.
Please explain why you want channel 5 to be the flignt mode switch.
