lipo vs props
heliuser
Hello, i see a lot of threads around "best" configuration and i know it all depends but i´m trying to understand better the configurations between 3s lipo x 4s lipo x 10 props x 8 pros . could someone share your experience on this ?Thanks
everybodies machines come out different weights after they build them out. if you have a stock 450 flamewheel with nothing else added to it, the recomendation on teh motor label is perfect, 10" and 3s or 8" and 4s. as soon as you add anything or furthermore change out motors etc, your targeting a mid stick hover in manual.
What do you have? what does it weigh? if it flies, where is the throttle stick position when it hovers.
are you looking for forward flight or stability to hover and take pictures?
heliuser
i have a f550. my goal is to take pictures so stability is my main concern. why the recomendation 10" and 3s vs 8"s and 4s ? its something like stability vs power ?
it makes hovering in manual mid stick. That means you've got it propped right, motors are most likely very happy, etc
how fast the motors spin is written ont eh side of them. yours probably says 930kv, that means it does 930 rpm per volt. 3s is 11.1, 4s is 14.8 volt. if your motors spin faster, you need less prop to achieve the mid stick bit. IF you set it up and it hovers at 1/4 stick in manual, when you give it full stick it is most likely over powering the motors, watts are too high and it will burn em up. if you take off and are hovering at 3/4 stick, your not gonna have much left when the volts wear down as in during the flight, the pack slowly looses voltage making less rpm till it only has a down motion and up is gone. this also usually means your not making the motors work to there full potential making not enough watts to carry it
So you notice i added it's all good as long as you dont add anything. When you put a bunch of weight on it you gotta increase the prop size to carry it again at mid stick. hang a gopro and decent size lipo off it and now your in that realm
the actual prop size is an efficiency thing. larger diameter is more efficient but are more succeptable to wind wobble or getting crappy handling in wind. 8" have less problems in wind, 9" is a great mid point, is what i use with 2814 1000kv motors, 4s packs
http://www.team-blacksheep.com/products/product:122
Dewster
Thank you Team Black Sheep! I just built a Y6 and I had to increase throttle past half just to get it airborne and hover. In manual mode the craft felt as if it would launch if I put the throttle past half mark. I may adjust the vertical gains after another test in manual mode.
