Pumpkinguy
I was early adopter of KDE and have to say - i am very skeptical of their reported numbers. just throwing that out there. Nice write up.
IMO their numbers lean heavily towards "optimistic".
I would only use the KDE 75's or the new Tiger 80's with the 4215xf-465's. The 55's aren't big enough to handle those motors. Just ask pumpkin!
Same here. I have over 70 hrs flight time with my 515's, and absolutely no bearing play. If I were still running tigers, i would already have to plan on bearing replacement soon. Tigers recommends changing at 80 hrs. KDE 300 hrs.
I thought the advantage was an extra bearing helping reduce the load/wear per bearing.
I am admittedly NOT a bearing specialist![]()
I never said KDE's have the best bearingsA manufacturer can recommend anything they want but what is so magical about kde bearings that they last 5x's longer? I'm repeating myself here for the people that don't know my background but. I was a "Certified Bearing Specialist" for 20 years. Servicing various industries. My kde motors came with NMB bearings. NMB IMO is not the best quality.
The kde 4215 and tmotor u7-490 are both rated for 3kg of thrust.
Some quick math tells me the u7 has a full 1/3 more stator surface area.
So, how is it possible the kde's are equal in output torque? Are they 30% more efficient?
I will point out that based on my experience with the kde 4215 it is a perfect motor for 2kg thrust with a 16" prop. It will run cool at that load.
It starts to heat up around 2.5kg's using 18" props. I have not tested it with 17's as I didn't have them.
I believe the 5215 motor is a better choice in the 2.5-3kg range as is the U7's.
Now the u7's have other issues. The t80a apparently runs crazy hot at the higher loads. Hot enough to melt the heat shrink tubing off but no reported crashes from this. If I go that route I will be adding 25x50mm heat sinks and 25mm fans.
I've decided on a 950mm Vulcan black widow frame.
Sorry, not trying to sidetrack the thread, but quick question I never got resolved about this frame - It seems to be a really popular choice, but are people worried about performance due to the low CG? A flat rig with a heavy camera and gimbal hanging off of it is enough of a "flying pendulum" as it is, the z-arms look to drop the weight distribution even lower? Or is that not a big deal??...
As I understand it you gain stability, but lose maneuverability.
In my previous career when I was selecting motors, gearboxes, chain, belt and gear drives for industrial applications I could always count onUpdate in the original post. In short, KDE's specs are nonsense. Their motor has a lot going for it and is probably the one I will use. But it doesn't perform even close to their claims.
