that size heli should have 28mm motors to do what you want, it'd want 900-1000 kv for 3s and 10" that'd also do 8" on 4s. 1200-1300 is 8-9" on 3s, there 250 watt so should live up to the call if everything is still in good shape..... i think your close to or entering some weird stuff. 18 amp motors, 30 amp esc's, not very heavy yet, but big. on mine balls to the wall is 60 amps and 16 volt, thats 960 watts. assuming all the weight was perfectly balanced and each motor made the exact same power at a sustained distance, you'd be right on the edge... I am now, the motors in the track vid are 250 watt.... just to put it all out there
turnigy numbers there stuff weird. most motors first two digits are the stator size, turnigy uses the outside diameter, i thinkin turnigy talk, 28mm motors are 35- if i'm not mistaken, The juz motors would be 28mm's and turnigy brand, see if you can reference what those are by google.
