maxwelltub
Im not sure if this is the best forum for lipo discussion but I'll give it a shot. I recently bought two Hyperion 6s split packs. I received them earlier this week, and right out the box they where not balanced perfectly, but pretty close. After a number of charge and discharge cycles I can not get these things to balance.
Important information to note; these are split packs wired in series to make a 6s. (part of the new shipping regulations, it sucks big time) They come with a little Y balance connector to balance them as a 6s. One cell is a 4s and one cell is a 2s. The ends of the Y connector are identical, but they are labeled with "A" and "B" tags that correspond to the two balance leads coming out of the lipo. Because they are identical if your not paying attention you could easily switch them up, and because the batteries in the split back are not identical I'm certain bad things would happen if you did mix them up. Because the split backs have double the wiring and soldering, I was very slow and attentive to detail when hooking up the leads and soldering the two pack in series.
Ok with that said back to the issue. I am charging on a Tenergy TB6AC4, and a back up charger which is a Thunder AC6. I thought maybe it was the charger which is why I switched to the back up to see if that helped. On the charger I have got one of the batteries close to balance, ranging from 4.20 to 4.17. However it will occasionally jump around to get closer to balance or farther. For example it will be 4.20-4.19 across the board, and then a few will jump to .17 or .22
The other one is mostly around 4.20-.18 execpt the second cell which is 4.12-14. When I use my stand alone lipo tester I get higher numbers, the highest cell reading 4.23 and the lowest reading 4.17.
I am currently balancing at 2 amps, and discharging at 1 amp to try and get these things closer to 4.20 across all 6 cells. I haven't flown with them yet for obvious reasons. It seems like its slowly getting better, but we are talking hours and hours of charging and discharging over the course of the week. Any suggestions or advice would be greatly appreciated. Am I doing the right thing? Am I making it worse? Is there hope for these little ****ers? Thanks.
