Hoverfly HoverFLypro Gains (Normal , AL , AH )
PaNt
Guys can you make something clear for me??
When you say gain you mean the gain in setup client or gain on TX???
Because as HF say i must have the same gain on MANUAL mode and on AL . what this exactly mean?? Same GAin on TX or on setup utility???
THANK YOU!!
Photronix
Pilot
same gain on TX. The gain in the setup client will be different for different transmitters. What matters is that you go fly on manual gyro only mode. Adjust your gain as it shows in the manual. Once you find a value on the TX that you are comfortable with then set the AL gain to the same value on the TX.
Ah, well I had this wrong as well! It's NOT clear, I agree. I thought we set it to fly in manual mode, then while plugged into the assistant we adjusted the AL value to be the same on the assistant, regardless what the value was on the TX. So if my value is 40 for manual on the tx, make the AL value 40 on the tx for AL mode as well. But it makes no difference what the numbers are on the assistant right?
PaNt
Yeap thats what phototronix say... Great because this was not clear..!! I cannot understand why if you put the same gain on tx is diffent on setup client??
Photronix
Pilot
Ok thats it....I am having the gain readout on the setup client removed! This has confused everyone since we added it.
BTW the manual doesnt say anything anywhere (that I am aware of) to adjust gains in the setup client. Can someone point me to the "un clear part"
JZSlenker
Yeah, I can blow that up.
I thought the point of the gain value in the setup client was so you can adjust your RX subtrim to make your EPA values to match on both sides of a given switch. Seems worthwhile to me.
PaNt
Hmmm thats might be right... Lets w8 for the hf supporters:):)
mdjohnson
Please keep the gain values in the setup client!!!! When I set my gains on my tx (JR9303) to read the same plus and minus (MAN & AL) the setup client showed they were not matched. There was a 5% difference and when I changed the tx settings to make the gains on the setup client match it did away with a little "jog" each time I switched between AL and MAN. A very useful tool.
Cheers
MJ
I think what happened, at least with me, was I called to ask about this and you guys verbally told us to do it in the assistant. So the mixed messages were what made it awkward. Then the +/- debate on which one was actually correct was confusing as well. It's one of those things where once you get it it's easy but for the first time it is confusing.
May I make another "ease of use" suggestion? I am color blind. And I also think it makes the wiring more difficult with the controller to motors using color rather than numbers. With numbers I can label the motor wires and if the inputs on the board were to make chronological sense, it would simplify that as well. Just a thought.
Yuri
Cheers
MJ
But Al is saying we DONT have to use the assistant to set it correctly, so why would you want to see the numbers at all? Not getting this.
mdjohnson
I'm sorry you don't get it. All I know is that I made the gain numbers in the transmitter the same (JR9303 + & - values which are MAN and AL respectively) my Y6 would always have a little "bump".......that is......it would very momentarily pitch up or down whenever I flipped from MAN to AL. No big deal but it did put a bit of a jog in my video. When I put the board back on the setup client for another look I was surprised to see a difference of 5% on the gain in the setup client between MAN and AL where the numbers should have been the same. I changed the transmitter numbers to get the gains in the setup client to match and voila....no more bump. Clear enough?? Maybe my tx settings and/or calibrations are out of whack but the setup client allowed me to fix a bit of an annoyance. Now my tx shows a difference of 4% between the + & - values. To do away with the gain readout in the setup client would be taking away a very valuable tool IMHO.
For what is worth, I used the assistant to match the numbers once I got eh manual gain right. So 40 on the TX was equivalent to say 43, so i made the other value 43 on the AL mode regardless of what it was on the tx. And I still got that little glitch when switching. It always made me nervous. But since .802 it doesnt do it at all. it flies so well whether I switch modes mid flight or start off in AL. It's pretty amazing what they've done. And to add it doesnt go crazy in the wind when in AL.
mdjohnson
Exactly!! That is why the gain readout in the setup client is so important. I'm not so sure it is the .802 firmware that does not give the bump anymore. I think that if you had mismatched gains for MAN and AL in the setup client you would still have a bump. I'm too chicken to try it on purpose!
periquira
So, what is the right answer?
Al gain = Man gain on TX
or
Al gain = Man gain on Setup
or
Al gain = Man gain on both ????????????
Please, someone from HF team answer this, close the topic and make the changes on the manual to become easier to understand.
I am getting really confused!!!!
Photronix
Pilot
AL Gain = Main Gain
If you want to make them the same value on the TX thats fine. If you want to make them the same value on Setup thats fine too. They should be only a few percent different and this is not going to matter that much.
The second Post on this Thread:
"same gain on TX. The gain in the setup client will be different for different transmitters. What matters is that you go fly on manual gyro only mode. Adjust your gain as it shows in the manual. Once you find a value on the TX that you are comfortable with then set the AL gain to the same value on the TX. "
or
or
I think if you word it just as you have it in that quoted sentence, it will be easier for most than what's currently there. I'm gonna sell all my DJI stuff and buy all Hoverfly pro's. I'm totally sold. Can you guys make me a single rotor heli auto le vel that works as well? :) now that we got this FS700, I am wondering what the safest way to lift it is.
Photronix
Pilot
What is the weight?
Wait just looked it up...~3lbs correct?
Our Scripta will fly that. The Erista would as well with room to spare.
Safe....I would also recommend 8 rotors over 1
