horizon / autolevel setting in baseflight with flysky ct6b
7808
Im trying to understand how to set up autolevel in baseflight with flip32 not plus version and flysky ct6b cheap 6ch tx rx. I dont understand why it has channel 1-4 and low mid high boxes but they seem to be associated with switches im guessing on the tx? Can anyone explain how to set this up? Ive watched all kinds of multiple 20-40min videos on baseflight and naze32 but its always with more expensive different transmitters
Old Man
Sounds like a situation where if you don't have the right tools you won't be able to do the job
Old Man
Don't know, I don't have all the minimum specification requirements for all your equipment. Start your research with answers to those questions and an immediate answer might be evident. If all the minimum compatibility requirements have been achieved then it's a matter of trial and error or finding someone that has done what you are trying to do with exactly the same equipment before.
In radio transmitter parlance channels one through four are usually assigned as elevator/pitch, ailerons/roll, throttle/thrust, and rudder/yaw in that order, generally as stick functions, not switches.
7808
I appreciate your replies, but it doesnt sound like have expirence with my issues, i know how to search, ive been doing plenty of it. I have it flying im just not sure how to set up autolevel with my transmitter, or if its possible.
Motopreserve
I've only dealt with the traditional multiwii GUI - but it seems like it should be same/similar. If you see the checkboxes in the GUI - those should correspond to aux channels that you assign in your radio.
Since you only have 2 extra available (as stated, first 4 should be the sticks), you'll need to choose which functions you want on the 3 position switches that remain (I assume they're 3 position).
The GUI for the radio should be able to show you which channels match with the aux. you can assign various flight modes with the positions on the switch (eg angle mode on switch 1 - low position, horizon mode on switch 1 - mid position).
The auto-level mode you are looking for should be Horizon in the configurator.
Motopreserve
You'll have to decide which 4 flight modes you need most, and assign them to the 2 switches. When you do - make sure you skip over the "mid" checkbox. 1 setting should be full manual mode for testing PIDs etc.
tstrike
pendejo grande
You'll also need to connect a servo cable between your flip and an aux plug on your receiver. Then go into baseflite and go to aux config and assign the channel to the function.
tstrike
pendejo grande
yeah, that's one of the reasons I abandoned the naze board, I kept slightly omitting things, too tweaky for me.
Motopreserve
I only have experience with the multiwii. Plenty of things to miss and mess up if you're not on your game.
Haven't flown multiwii in a while - but the learning curve was enough at the time for basic setup to be etched in my brain!
7808
thanks guys. ill give it a try.. they always have nicer transmitters with 3 way switches and easier to set up with displays on the tx in the videos.
7808
how do you assign a channel? I have an extra servo cable hooked up 5th channel , feel like im missing something here.. I feel like this board is probably very good in the right hands but I might be more of a kk2.1 person. I don't have time to mess with all this crap just to fly the thing ive already spend hours building. im horrible at flying without any kind of auto level.
im already using channels 1-4 obviously, how do I know which channels baseflight thinks are aux 1 2 3 4 ? when I flip a switch I don't see the shaded box move from low mid high. I have one extra channel hooked up. channel 5.
Motopreserve
Have you had the radio application open and checked out the settings that radio currently has programmed?
All changes/assignments on that radio are done via the app. The good news is there is a computer GUI, so checking your work is a snap.
Once you have the app GUI open you should be able to synchronize the radio so that you see all settings. Then when you choose the aux setting you need - you should see that the radio is responding to the input right there in real time.
7808
that's how I see it in the videos, mine however does not. I have channel 5 of my receiver connected to input 5. I can see my stick inputs in baseflight but nothing happens in the mode settings screen. pretty sure im missing something simple. maybe I need to set a switch to a channel in the t6config software for my tx ?
I just found a thread for my exact situation http://www.rcgroups.com/forums/showthread.php?t=2278673
