jfro
Aerial Fun
My x8 had been flying very nicely.  Today, all hell broke loose after trying some new props on the bottom.
I fly it without camera (my light setup) and on futaba, set endpoints (gains) to high 20's to low 30's.
When I fly it with camera (heavy setup) the futaba endpoints are up around 80.
Today, experimented with 12x4.5 prop on bottom instead of 11x4.7 in my light mode (no camera).
It launched as expected. I flew maybe 3-4 flights of maybe 20 - 30 seconds each changing the gains each time Most gains were roughly 76 and on up to about 100 today with the bigger props. I might have tried a lower gain, but don't really remember. Didn't like it so switched back to 11x4.7's on bottom.
Battery wasn't even warm when I made the change.
After changing back to 11"props, I didn't have much control. It's trying to level itself pitching left - right and front and back. Have tried gains from 26 to 90. Higher numbers are more problematic, but nothing is even close to rising 4-6 ft and being level. It gets up a couple feet and goes all over the place. After each crappy landing (on very soft soil with longish grass), I check motors and landing gear for alignment.
I reset cables, checked tightness of props, changed battery, changed over to a different model (setup) on my radio that I was using until last week, etc etc.... All motors seem to be spinning properly and it sounds normal.
Finally, on about 8th attempt I took it up a little higher to see if it would level (which it didn't) and came down losing 2 props on bad landing, so i quit for the day.
I guess my big questions is how long does the HFP black board take to adjust after changing the gains?
Does changing the gains make other changes?
Does making large changes totally confuse the fc?
Thanks in advance for any advice on how the HFP board works and what I should try next.
