Bart.... if you lived closer, I'd have beer and ribs waiting for you.
But, I'll just have to keep mucking my way through this.
My turnigy's 30amp plush are as follows
These settings were suggested by Hoverfly in a phone conversation.
brake off
battery type nimh/nicd
cutoff mode Reduce Power
cutoff threshold high
startup mode ...normal
timing middle
Bart suggests......
1. Brake--OFF
2. Battery Type -- Ni-xx
3. Cut Off type -- Cut Off
4. Cut Off Voltage -- Low
5. Start Mode -- Normal
6. Timing Mode -- Middle
7. Music/Li-Po -- all blank
Governor Mode -- OFF
So I will make the changes. Any shortcuts for reprogramming the ESC with all my cables soldered?
Wondering if I can take off props, discount all esc's from receiver and just plug in whatever esc I want to program into channel 6 on my receiver.
I would assume the other 7 motors will just sit there beeping if they just get power but no signal?
I'm a little hesitant on the cutoff, but I'm guessing I'll never go that low.
What is modern theory on how far I can deplete my batteries without shortening their life? I've read heat and to not go below 3v per cell.
Shall I use time or voltage alarm or both?
I don't mean "are they spining the correct direction", I mean do you have them oriented correctly. If they are upside down, you will fly smoothly, but have poor efficiency.
Larger prop with higher pitch should go on the bottom. I think Jet2Man did exhaustive testing on this subject. Most people quote theory, not actual test data.
Don't get caught up on looking at voltage too much when comparing to others. Battery brands exhibit different discharge characteristics. What you really need to look at is how many ma you are using. The only way to do this (without onboard sensors) is to look at how much ma you put in when you charge and how much goes in when you re-charge the next flight. Voltage becomes even less reliable as a comparison factor when you start using higher quality batteries as the voltage drop occurs right before the capacity is exhausted.
Webheadfred & JZSlenker.........
Thank you for spelling it out. My letters (11x4.7) on the bottom prop are facing down. Never read anything about that. Never thought twice about that. Put em on the motors just like on top.
Checked the rotation and have flown probably 60-80 batteries like that.
This reminds me of my 2+ decades of building and troubleshooting computer systems for graphics, prepress, and video. Sometimes you spend a lot of time on some little thing you overlooked or never thought of. I've spent so many hours noodling and fretting about my flying times....
I'm going to change the bottom props right now, catch some crap from the wife unit while I blow off her honeydo list, and go try it......
I'll report back....
