Brian Iannone
I'm new. *Really* new...
Hello everyone. My name is Brian and this is my first post here. I'm new to both this forums and multirotor copters in general. So, nice to meet you all.
I am a photographer and filmmaker. Recently in the world of cinematography, octocopters have become increasingly popular for aerial shooting. I personally like the idea quite a bit as its much less expensive and much more convenient than renting out an actual helicopter (to say the least).
So, I would like to build an octocopter. Before I begin though, allow me to say that I know nothing about RC devices and have no experience flying helicopters or multirotor copters, so I apologize if I use incorrect terminology.
I would like to use a CineStar 8 frame and build an octocopter by either purchasing a build-your-own kit from Quadrocopter.us or individual components and assembling it myself. I liked the idea of Quadrocopter's ready-to-fly kits, however as with most products that come ready-to-use, I assume that there's some overhead cost in the convenience of having it preassembled. So I'd like to avoid that.
Here are my questions:
1. I see that Quadrocopter's CineStar 8 kits uses QC3328 motors. The specifications list this octocopter as being able to lift approximately 2,000 grams, or 4.4 pounds, of weight. Is there any way to get this octocopter to lift a heavier payload, either by using different motors or by reducing the throttle while flying? If so, what would you recommend? I plan on using a Blackmagic Cinema Camera (weighing 5.1 pounds) with this copter.
2. Quadrocopter's CineStar 8 octocopters come with MikroKopter flight control system. I've heard quite a bit about DJI's WooKong-M. Is one better than the other? And also, is it possible to install WooKong-M into one of Quadrocopter's build-it-yourself CineStar 8 kits?
3. I watched a few of the assembly and setup videos on the CineStar 8 and it seems like there's quite a bit of calibration to do once assembly of the octocopter is complete. For someone like me who knows nothing about octocopters or RC devices, will this be impossibly difficult or doable?
4. I would like to use the CineStar 3-Axis Camera Mount. Can this mount support the weight of a 5.1 pound camera while still maintaining motor control? Also, how is the gimbal controlled in a one-person setup? (I would assume with the same transmitter that is used for controlling the octocopter.) If so, how many channel-support do I need in a transmitter? I was looking at Spektrum's DX18. Any thoughts?
5. Is there any way to get this CineStar 8 to lift a 10-15 pound payload? My primary camera is a RED Scarlet, however I chose to purchase a Blackmagic Cinema Camera to use solely as my "aerial cam" as I was told that an octocopter capable of lifting the weight of a complete Scarlet or EPIC setup (around 10 pounds) would cost at least $20K. My budget is currently $11,500 for an octocopter.
6. In terms of wireless video transmission for a live feed on the ground... To be honest, I'm not sure I understand what specific components are required to achieve this. I would really appreciate a list of what I need to for this! One issue I became aware of is that many live video systems require the camera to supply a component or S-video input. The Blackmagic Cinema Camera has an SDI output. One possibility is to use a Blackmagic Battery Converter (weighing 0.8 pounds) to convert the SDI signal to HDMI and then use Freefly's HDMI Converter to convert the HDMI signal into something usable.
7. Freefly's Radian Stabilization Module... My question about this is basically, how do I incorporate this into the octocopter, what do I plug it into and how much do they weigh?
I do have more questions, but after reading some answers for these I'm sure I will have a slightly better understanding of this system.
I do apologize about my number of questions, but I quite literally know very little about this. I would really appreciate any help!
Also, I posted these question on another RC forum, but as of now, have received no answers (to my actual questions) due to the fact that everyone there has been instead stating that I should start off with a smaller, inexpensive [FONT=arial, helvetica, sans-serif]multirotor copter and learn with that. I'm not concerned with flying this octocopter; only building and configuring it. If it turns out that flying this truly is impossibly difficult and I find myself unable to do so, I have a pilot able to takeover while I stand by.
So, I really would appreciate some answers. =)[/FONT]
