ROVguy
Ok, so Ive been looking into the forums for a while now and trolling the internet trying to get as much information I can about MRC's before I end up purchasing. Ive pretty much decided to go with the DJI F450 or F550 kit with Naza+GPS and bits 'n' bobs (Ive got a £1.5k budget so this could change unless I decide to jump into FPV straight away). Ive found a lot of information during my research and it is slowly penetrating my thick skull. However, trying to get my head around the Lipo - motor - prop = thrust + flight time correlation is making it hurt!!! I just dont get it! I think the 2S, 3S, 4S thing is the number of cells and thereby the voltage of the battery? Im not entirely sure what the other specs are, although I know the mah is the capacity of the battery, the bigger the number the larger the capacity, but also more likely the greater the weight? The 25/35C, 30/45C bit confuses me a bit, is it the amount of current the battery can provide?
Basically what Im trying to find out is what goes with what with respect to the battery, motor and prop. Do you go with a larger prop and slower motor to have greater lift or smaller prop and faster motor? What battery type would you need? If you change your battery type would you need to change your FC given the change in voltage? Given a few comments previously on here Im presuming the size of the prop also has a baring on the stability of the MRC and its performance and handling in the wind?
As you can tell my heads a bit mushed up and I think Im starting to lose it a bit. Any help any of you guys could provide would be very much appreciated.
Richard.
PS. Whats the general consensus of Radio Transmitters? I was thinking of going with the Spektrum DX8, but after having a look around on here Ive noticed a lot of people use Futaba and that you can incorporate UHF modules with them to get greater range? Theres this DHSS and FASST malarkey. Which way do I go? Would it be better to go for something with more channels for future usability or just stick with the 8 for now and upgrade again later? I can get the Futaba 8FG Super 14-channel S-Bus including all the gubbings for an extra £130 over the DX8. And whats this S-Bus, PPM, PCW all about? Whats the advantages disadvantages?
Sorry for dumping all of this on you.
Richard.
