Yeah, HDMI output is different than record quality and won't affect recording. I mentioned 720p simply because on the GH2 that is the preferred setting. You should find it in the settings menu somewhere. On the GH2 is is simply called HDMI.
Correct me if I am wrong but the GH2 will not record in 1080p if you plug in the HDMI, it will revert to 1080i no matter what you set the mode to record in.
Hey Matt,
Just out of interest how are you trying to view the live feed? On a TV set or monitor directly or through a video transmitter and then a receiver?
Still sounds like a camera setting. What have you tried so far? Tried the settings mentioned in this post like HDMI output and PAL/NTSC?
Just keep changing settings. Something will click eventually or someone will chime in with the solution. I had this problem when I first started and it was the HDMI output. I had it on automatic (which was wrong) and it had to be 720, this is with a GH2 so different to the problem you're having.
