Hi, firstly i have 5 multicopters in total, S800 Hex with Naza Lite & AR8000 RX, Dji F550 with Naza Lite & AR8000 RX, Dji 450/Naza Lite & AR6200 RX, Discovery Clone/Naza Lite & AR7000, Dji F330 with KK2.1 Board, all were good except the F450 would not preset bind with the AR6200 RX, so i got my hands on a Spektrum AR7100R Heli RX and connected it carefully to my Naza, i put in the bind plug and powered it all up, the RX flashed an orange led and seemed to bind ok with my Spektrum DX7s, but the Naza LED Turns green for an instant then goes solid Red,i tried to connect to the Naza assistant but it does not seem to see the naza unit, i then refitted the AR6200 again very carefully to ensure propper connections, but my Naza Led still stays solid red ? The AR7100 has an extra heavy red/black wire for direct connection to a lipo for heavy consumption setups, i DID NOT connect this plug to a lipo, as i wanted to use the standard BEC from the LED unit, so over voltage should not have occured, i tried the assistant again on another model and it worked fine so there is no driver issue. i cant understand what has happened and would appreciate any thoughts.
Thanks all.
Thanks all.
