Has anybody got any video shot with a GH3 on the new Zenmuse yet?    Specifically I would like to know if anyone has any video shot in MOV please?  the reason I am asking for this is that the Z15 manual states to shoot in 1080i and MOV is progressive not interlaced, does it make a difference can you shoot in MOV with the Zenmuse?
I don't have a GH3, i do have a GH2 though, however..anything in the Zenmuse manual regarding how to shoot proper video, throw it out the window.
I believe I read it once, and it even states you need to be shooting in aperture priority mode.
Are you having any problems with your videos?
The first thing you need to do is get the fastest sd card you can get your hands on.
You should be able to use All Intra compression in MOV mode but this has 72Mbps output.
You need a really fast SD card best ones are usually Lexar class 10 minimum, don't skimp on them, buy the best you can.
Need to know a bit more about the settings you are using at the moment, also what you are using to edit with, FCP or Adobe, Adobe PP will be able to handle it much better straight out of the camera.
You should always choose progressive over interlaced if you can.
I am considering getting the GH3 myself, and will be able to help more if I do, but I am just going from knowledge without actually using the camera.
Hopefully someone who uses it will be able to also provide more information.
Set the camera into manual, set shutter speed to 1/48 and leave it there, and adjust your aperture and ISO to suit.
