Diviner Gregg
New video every other Friday. And race day Friday comes a little early this time. This is the first of a new series called "Race School".
another good video Gregg. keep it up
Just about got it organized. We are still discussing if we want to run just a spec class or add an open class or just have an open class. some of people went all out on there builds on power, but as i have seen in practice most of there set ups pull the same times and slower due to all the twists and turn. But yea its coming around nicely. Should be a fun season.
The thrust tests have the 1806's on par with the 2204's. In fact the dys 1806 has more thrust than the second generation SS 2204. I am glad I did follow the SS heard on that decision.
How we do indoor racing in Australia...
And some raw footage...
I think you'd better have a look at some proper thrust tests cause then you'll see the 2204's destroy the 1806's when put under higher load. Sure there's little difference with GF 5030's but who in their right mind runs those anymore? Fact is when you push an 1806 with something like a HQ5x4.5 bullnose prop it can't take it and heats up where the 2204's love it. Of course when you go 4s the gap gets even bigger.
There have been some pretty inaccurate and inconsistent tests done by some people. Check out the trust worthy thrust testers like Soma on RCGroups.
Regarding reducing rates, never ever reduce the rates in your tx as that just reduces the resolution in the stick movement. Always adjust rates in the tx to 125% and then adjust the rates to suit in the FC.
Hmm. I got my data from Soma.
I will summarize DYS 1806 vs Sunnysky 2204. For more info, google "Thrust Test DYS1806" and "Thrust Test Sunnysky 2204".
DYS BE1806 2300KV Brushless Motors:
HQ 5040 Prop - 440 Grams pulling 10.6A @ 100% / 225 Grams pulling 4.2A @ 50%
SunnySky X2204S 2300KV Brushless Motors:
HQ 5040 Prop - 360 Grams pulling 8.9A @ 100% / 135 Grams pulling 2.2A @ 50%
According to Soma, the Sunny Sky's are pretty much worthless in the 2204 class. Many people refer to Soma and EngineerX on RCG. But I believe they only test 1 motor, so they have a sample size of 1. But I have done real world in flight blade thrust testing (see my blade shootout video) and my results were on par with bench tests, so I have no reason to doubt of his results since they matched my real world flying tests. My real world testing also tests handling and air resistance, something not easily tested on the bench.
People make uniformed decisions. But in the 2204 class, SS's are the worst if we believe SOMA and others. In fact, the difference is significant for the blade we use in our spec class (hq5x4gf SS 360 vs DYS 440).
A lot of newcomers to our race league start out wanting SS 2204 since that is what they hear. I created a performance knowledge base for racers in our league and give them data to make an informed decision. For motors, that leads them Cobras, TT and a few others, but not SS. For the budget minded, we direct them to 1806 for the spec class, or buy a bundle. One of our sponsors offer a 2204 upgrade from the 1806 for only $4 more. That only $1 per motor! And its a decent motor (Emax2204) that they don't have to upgrade for a long time.
Most people only use half of their stick throw which forces them to be very precise and that creates slower times.
Perhaps we have a terminology problem.
You want more stick movement (stick resolution) for racing, not less. You do this by first setting up your FC and radio for acrobatic flying. Then for racing, add dual rates which will send out a porportionally lower PWM across the entire stick throw . This means you have to move your stick more to do a turn. For racing, you don't need much throw to do a 90 degree bank turn. I use 70% on my Taranis. That way I use all of my stick for turning. And I don't have to touch my FC.
Another tip that will be in my next video is to increase the stick tension. TX manufacturers stick need to be stiffer which makes finding center easier. This is one of the first things I do with noobies.
A third trick is to change some of the naze commands. Resolution can be improved by changing Throttle setting / min and max. For my motor/esc combo I use 1810 and 1100. Before changing this, I was losing about 20% of my throttle resolution.
Hi Bartman, no I'm not associated with any company. I'm just part of a group of mad keen racers that enjoys pushing designs and setups in mini racing quads. I am good friends with Soma who makes the Warpquad frames but don't have anything to do with the business. I just enjoy his awesome products .
