skivvie
I posted all this originally at RCG, but think it would be appreciated more here so I'm duping it
Quickly: The craftsmanship of this frame is phenomenal. They thought of (almost) everything and the quality is as good as you can get.
Setup so far:
Flexacopter with all the options including a gooseneck front arm.
DJI Wookong M
HiTec Optima 9 Rx (w/ Aurora 9 Tx)
Avroto 2814
Maytech 35A OPTO ESCs
Graupner 11x5
Voltair distro board (as well as custom spider)
Zippy 4S 5000mAh (2 in parallel)
PhotoHigher AV130 gimbal
Castle BEC at 6.5vsome LED strips
This build might be up for sale soon so if you are interested let me know...
And now for lots of photos!
Fresh out of the box:
Flexacopter parts by Loren Cox, on Flickr
Planning out the placement of ESC and Voltaire power board:
Flexacopter hub by Loren Cox, on Flickr
The ESC's all soldered with 3.5mm bullets. I don't trust that I'll have these ESC's on forever with all the flashing shenanigans going on so I want them easily removable. They are Maytech 35A OPTO v1's.
ESCs soldered w 3.5mm bullets by Loren Cox, on Flickr
Scared of running it all through the board, I decided to be safe and make a simple power distribution spider for the ESC's with a 7th leg for the distro board which will make it easy to add extras as I go. I'm sorta throwing caution to the wind weight wise but i'm not to worried about an extra 100 grams give or take. Soldered up a power distribution spider... I'm not sure which I trust less, the spider or the Voltair! That's a lot of solder.
Held together with copper wire before soldering.
Power distribution spider by Loren Cox, on Flickr
Soldered up
Power spider soldered by Loren Cox, on Flickr
Not bad, pretty clean blob
Big wad of solder by Loren Cox, on Flickr
Liquid tape is next... laid out like this on the hub, all wires in the middle. Voltair board on top for easy addition of accessories. Make sense?
Power layout by Loren Cox, on Flickr
Liquid tape is awesome
Power spiders by Loren Cox, on Flickr
And so is heat shrink.
Power spiders heat shrunk by Loren Cox, on Flickr
Laying out the spider
Power distribution layout by Loren Cox, on Flickr
Setup so far:
DJI Wookong M
Avroto 2814
Graupner 11x5
Soldered up
