First Time FPV last minute thoughts
usnooz
I'm all ready for my first FPV flight and just wanted to check positions of stuff and any last bits of advice.
I know its good to get high early and fly in a wide open space. anything else?
Here is where i've places my Camera and Tx (fatshark 100mW)
View attachment 5731 View attachment 5732 View attachment 5733
hjls3
sit down in a chair. i understand standing up is not the way togo. I have never really done FPV though but I too am trying to get all my ducks in a row. i will be doing the same soon. anyways good luck!!!
Jackella
yes,defo sit down and relax.Also make sure the viewing camera is pointing at a good angle downwards.Be easier to land etc if you can see the ground clearly.
Also point the quad/camera towards something you are familiar with on the ground,i usually aim it at myself, so on take off you get accustomed to your surroundings quickly.
RTRyder
Merlin of Multirotors
Yes, sitting down is a good idea especially if you get motion sickness, some people find they get dizzy seeing the landscape flying by while they're standing still. Not that sitting down will make that not happen, but at least you can't fall over if it does... ;)
If possible have a spotter nearby to let you know if you're getting too close to anything that you may not be able to see in the camera field of view and for the first flights it may be easier to be in the middle of the largest unoccupied open space you can find, first flights tend to be very adrenalin producing so make things as easy and relaxing as you can until you start to feel comfortable flying remotely. Took me quite a few flights before I was ready for take off and landings via FPV view, I usually got the multi off the ground, engaged altitude and position hold (Mikrokopter flight controller) then put the goggles on and flew around. Back to landing zone and reverse the procedure to land, goggles off then disengage AH and PH to land visually.
From there I progressed to takeoff and flight but still landing visually and after enough stick time I felt confident to do the entire flight FPV, now I try to land within a small predefined area to see just how accurate I can get on landing, usually within 2 to 3 feet of the takeoff point :)
P.S. you may want to do a couple flights without the GoPro in the case until you build some confidence, the case can take a lot of abuse but there's no reason to subject the camera to possible crashing for the first flight or two. Just make sure the center of gravity is correct without the GoPro if you decide to go that route.
i kept looking at that mount thinking i've seen that before..... is it the piece the packaging comes in?
I notice you got all your electronic gadgets together. vu over the radio rx next to the video tx, etc. seperation in fpv is crucial. esp with a 100mw transmitter.
Let us know how it goes and i'll be glad to try figuring it out. the rubber antennas generaly suck. 100mw works with really high gain antennas better and CP polarized because quads tilt to move, makes hor/ver polarized antennas not work well
usnooz
I can tilt the camera in flight so i might try it when landing
Yes its part of the packaging. it seemed a waist and it works well on there :)
I guess i'll try it as is and then move it to see if it improves or gets worse.
I have been looking at the cloverleaf antenna. guess that will be my next buy.
you might ground check it. i'd turn it all on, put it in atti so the light flashes and walk off recording what your goggles see and looking for that light to mess up at all like double spark, miss a spark or if setup properly, failsafe light
if was mine, that video tx would be up by the cam, the vu would get out on an arm. i like the rc rx down under, fine.
Wish you were closer, i'd make you a set at cost
usnooz
I'll look at moving stuff around like you suggested. Nothings nailed down so its all relatively easy to move around.
my first tries were miserable with 5.8, it is so touchy, did as i suggested and had somehting like this
in my handin the house, it was totally clear. in case you can't tell, that isn't flyable. 3 months later and a huge knowledge of the stuff later, i was looking like this
the main difference in those two was the cloverleaf on the quad was on a mast, about 4" tall and the ground station (tracker) has a high gain directional patch antenna called a crosshair, all CP
