Tried drone in house and linked drone and controller first, then unlocked props with controller, and they started to idle spin (spin at low speed)  then used left throttle stick and it would start to fly, so far so good.  I would catch it by its landing gear so not to hit something and then throttle down and put it back down with my hand.  Then i tried to use my  iPhone and the Drone 2 app.  The camera worked, with the WiFi so i could see the image from the camera on the phone.  Also, google maps was showing up well.
After this, i could not get the props to increase speed over idle speed using the left throttle stick, and the right joystick did not change the motor speeds either for roll left or roll right or forward or back. I did re-calibrate the drone with two different axis rotations like it shows in the manual to now avail, and tried two different batteries.
I so bad wanted to fly it today outside and could only lock and unlock the propellers with the controller by moving both joy sticks down and to the outside. Any help would be appreciated.
Bottom line, can't get drone to take-off!
Thanks!
Thanks!
