http://api.ning.com/files/PZkfthj5s...GqflgQaJRBvCTs7WMsoL*WrGQ__/Motor_edited1.jpg
like these??? I can't find any info on them!!!
Might take the bolt pattern dimensions and see if theiPower MT Prop Adapter/Cross from gotheli would work http://gothelirc.com/shopdisplayproducts.asp?id=179&cat=Prop+Adapters (bottom of the page). A suggestion I would give you is to ditch the nosecone prop bolt and go with a nylock nut of your size (6mm?), those cones are notorious for being out of balance.
Try plugging in this part#GS0163M, I'd still ditch the cone and go with a nylock. You have to grind a flat spot on the motor shaft so the grup screw bites, I like them waaaaay better than the cheap chinese aluminum collets, but I break things easily.
