Been having issue with my F450 and NAZA. It Constantly moves to the left and fails to altitude hold (have set switch on Tx to flick to 50%)
This evening I gone through yet more testing after Kloners help (thank you). I had tp push the Pitch and Roll gains upto 320% in order to get the copter to vibrate however this did not stop the pull to the left.
So far I've:
Spent hours on various gains
Tried the battery in different postions, further to the right to counter the left pull
Remounted the NAZA (used a bubble level to check its level)
Moved the props around
Tried both 8inch and 10inch props (3s lipo)
Tried various setting on my DX8 - set up both Airplane and Heli modes
Rebound the TX and RX several times
I've even tried inserting some folder paper under the side of the NAZA to lift to see of it would stop the left pull
None of this stops the pronounced left movement. All I can think of now is the NAZA is faulty.
Anything else I can try. Getting very fed up with it
So far I've:
