EUREKA!!!!!!
I have talen drastic measures to isolate the possible intermittent connections caused by the easily rotating contact element of the 9212 motor connectors to the ESC. I CUT THEM OFF AND SOLDERED THE WIRE DIRECTLY TO THE ESC CONNECTOR !!! It is not has difficult as it initially seems, you need a fresh X-Acto blade however to cut off the heat shrink and not the wires. As the ESC connector is hollow and capped at one end, the soldering is very easy. I replace the heat shrink with new one (Don't forget the install on wire BEFORE you solder...). I don't want to be overexcited as I only have 3 X 10 mins flights with the F450 so far BUT, ABSOLUTELY NO GLITCHES, STEADY AS A BAR, IT SEEM TO FLY HAPPY AND SMOOTHLY, JUST AS IF I JUST GREASED THE BEARINGS AFTER FLYING A WEEK WITH DRY BEARINGS (figure of speach of course...). Looks very promising, I continue the testing with an increasing smile!!!!!!
Will report progress again after a dozen more flights!
