Wow! that is really cool. If you fly that outside at night I'm sure there will be a lot of UFO sitings reported.
How did you make the dji arms to accept the cf arms?
Verstuurd vanaf mijn SM-N9005 met Tapatalk
Milled off the ends, milled a 16mm hole for the CF boom and lock in with a through bolt.
I have built a few X8's by either modifying the DJI arm and adding an additional mount or using Tarot mounts, 16mm CF tubing and milling some old broken DJI arms.
Using 16mm X 320mm CF tubing I can cut them in half for an F450 or use the whole length for an F800
This is the results.
This one doesn't really count but I do believe it's the only X8 Phantom out there.
